Starting problems
Old Feb 5, 2005 | 11:49 AM
Default Starting problems
a couple months ago i started to have problems starting my car. it would start but it would take a few tries. battery was dead so i replaced it. spark plugs werent in the best condition so i replaced them. both helped but its still not starting like it should. what should i check/replace next?
Old Feb 5, 2005 | 11:55 AM
hamhead's Avatar
If you didn't replace the wires, replace those. Next step would be to check the grounding, and then the alternator.
Old Feb 5, 2005 | 12:02 PM
paperstsoapco's Avatar
<div class='quotetop'>QUOTE (hamhead)</div><div class='quotemain'>If you didn't replace the wires, replace those. Next step would be to check the grounding, and then the alternator.</div>
I agree with hamhead. When you say its not starting like it should, what exactly is it doing ??
Old Feb 5, 2005 | 12:10 PM
ill turn the key and it will try to turn over but it wont until i either hold it for a while or try like 3 times. i was thinking probalby the wires next as well. where would be the best place to get those from
Old Feb 5, 2005 | 01:00 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
your starter turns engine slower then it should be or you your engine is turning ok but not starting?
Old Feb 5, 2005 | 01:03 PM
Yes engine is turning but not starting
Old Feb 5, 2005 | 01:20 PM
Dmitry's Avatar
is it differs when you start cold engine or warmed up?
Old Feb 5, 2005 | 01:40 PM
It does start up quicker when it is warmed up already
Old Feb 5, 2005 | 02:31 PM
Dmitry's Avatar
check spark plugs, spark cables and connections of wires.
Also it can be caused by faulty injector - one (or more) injector(s) can pour fuel when it should be closed. And your engine wouldn't start until it will be ventilated (couple of times you turn it with starter).
Is your fuel consamption the same as before your starting problems?
Is your idle stable?
Old Feb 6, 2005 | 11:56 AM
Idle has been stable and there is a slight change in fuel consumption but not huge.
