wiring above the clutch pedal
Old Mar 12, 2005 | 02:55 PM
tib1386's Avatar
Default wiring above the clutch pedal
i have a 2001 tib and i was wondering if anyone else has notice a group of wires that are right above the clutch pedal. and if you put your foot to high on the clutch pedal you hit this group of wires. has anyone else had this problem and if you did how did you fix it?
i did a search also and came up with nothing
i can also take a pic once the digital cam recharges.
Old Mar 12, 2005 | 03:11 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
1.you could hook those wirings to something
2. don't touch it with legs (joke)
pics will help.
Old Mar 12, 2005 | 03:26 PM
tib1386's Avatar
it is pluged into something. going to take pic now
Old Mar 12, 2005 | 06:38 PM
zhiryst's Avatar
By any chance, are you referring to the ECU wires wires go to a huge connector that ends at a metallic boxy thing)? or maybe the ODB 2 connector's wires(wires that go from the ecu to a connector that is at the bottom of the dash, way below the steering wheel)?
Old Mar 12, 2005 | 06:44 PM
01roller's Avatar
just get some electrical tape and tape it to something higher, or reattach it to whatever it fell from, your wires probly just fell down slightly
Old Mar 12, 2005 | 08:21 PM
tib1386's Avatar
When i got down and looked at it it was this huge group of wires. i grabbed a big zip tie and tied it up high so it was out of the way. but man was the the group of wires big. the was a space higher up tht they normally fit in i think and they feel down. problem fixed thanks for the help
Old Mar 13, 2005 | 12:45 PM
TibRacer01's Avatar
Does your tib have an aftermarket alarm or keyless entry?
I had the same problem, and I found out that it was my alarm.
