Compression Test
Old Apr 18, 2005 | 11:11 AM
ok im about to do a compression test what is acceptible specs?
thanks
Old Apr 18, 2005 | 11:55 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
Quick glance at webtech:
Standard value [at 250-400rpm] 14.5kg/cm2 (1.47Mpa, 213psi)
Limit 13kg/cm2 (1.37Mpa, 199psi)
Max. difference between cylinders 1.0 kg/cm2 (100kpa, 14psi)
I guess for turbo charged engine standart value is lower (12 kg/cm2 - due to lower compression ratio).
Old Apr 18, 2005 | 12:05 PM
hamhead's Avatar
^^ Definately sounds about right. What mileage do you have, and post your results, so we can see how these cars age, at least in your case. tongue.gif
Old Apr 18, 2005 | 12:57 PM
well mine right now are as followed
1. 177
2. 176
3. 154( it went down to 124 then i retested and it went to 154 i think i have a stuck hla cuz it ticks bad)
4. 179
hmmm my engines gettin tired (138000 miles)
on cyl 3 it went down to 124 then i retested and it went to 154 i think i have a stuck hla cuz it ticks and ive ran seafoam through twice and it still ticks
boo hoo no nitrous on this engine
Old Apr 18, 2005 | 01:57 PM
tanc's Avatar
Vehicle: 1997 Tiburon
Can you shae how you did this compression test?
Old Apr 18, 2005 | 02:12 PM
you pull out the spark plugs disconnect the ignition pack and install the guage and crank the car over a few times
Old Apr 18, 2005 | 02:16 PM
Dmitry's Avatar
Compression test by WebTech
Old Apr 18, 2005 | 09:26 PM
hamhead's Avatar
Faith, your Tibby's tummy may soon need a heart transplant.
Old Apr 19, 2005 | 12:56 AM
hmmm would hla's throw off the compression?
the car runs strong and were i hit 154 is were i think the lifters are goin flat
when i raced abqelantra in his 04 i beat him everytime except when i missed 2nd (at the track)
and the only thing extra i had was less weight and a flywheel
he had less milage and cvvt
it idles pretty good (when the subs are off) and ive never had the head off of it
it doesnt really burn oil i think it burnt around half a quart last oil change
and not once has it overheated EVER and i dont smell antifreeze
still has the factory thermostat, factory hoses, factory drive belts cam and crank seals are still the same
i think the only engine thing ive ever done (other than mods) was i had the timing belt replaced around 85k and im at 138 now
most used engines i am lookin at say around 160
wait i just looked at webtech i did the test with the throttle closed maybe i should redo it
Old Apr 19, 2005 | 08:31 AM
Dmitry's Avatar
Yes, you should redo.
You should check compression pressure with wide open throttle.
If you have low compression - add oil through the spark plug hole (a bit) and check compression on that cylinder again, if it goes up - problem with piston rings, if no - valves, head gasket.
