Steering Wheel Problem..plz Help
Old Apr 30, 2005 | 08:32 AM
98tibby8289's Avatar
yesterday i was driving my tib and i noticed when i take my hands off the wheel and the cars in motion, it jerks to the right a little bit and i have to move it back to straighten it out..can this be fixed easily? thx <_<
Old Apr 30, 2005 | 08:37 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
First of all - check tires pressure.
If that not help - you need to do a wheel alignment.
Old Apr 30, 2005 | 06:07 PM
This could be a number of things.. some cheap to fix, some expensive.
Start with your tire pressures, one lower than the other can cause a pull
Could be tierod ends. Those are cheap from the dealer, but you will need a re-alignment after replacing it.
Also check your bushings on the suspension. A bad or mushy bushing could change the alignment. Does the car straighten out some when you apply throttle? How about when you back off?
If all of the above fail, check your brakes for a dragging caliper. A drag can pull the wheel to one side. A good indicator is the wheel goes straight when you apply the brakes and the drag equalizes.
Above all else, check on a level surface and in a controlled enviroment where you won't have any problems with other cars or the police.
Old Apr 30, 2005 | 08:01 PM
UltraTibby's Avatar
Now one thing everyone forgot to ask is that when you took your hands off the wheel were you still giving it gas/braking or were you off all of the pedals? That would make it alot easier to explain/fix.
Old May 4, 2005 | 06:22 PM
<div class='quotetop'>QUOTE (UltraTibby @ Apr 30 2005, 10:01 PM)</div><div class='quotemain'>Now one thing everyone forgot to ask is that when you took your hands off the wheel were you still giving it gas/braking or were you off all of the pedals? That would make it alot easier to explain/fix.
well it seemed that if i wasnt giving it gas or was it was still pulling to the right a little bit....i gotta check the tire pressure that maybe the problem....i hope its nuthin 2 serious
Old May 7, 2005 | 07:21 PM
hey thx guys for all the help it actually was just a minor problem i noticed my front-right tire was a little flat so i pumped it up and it's fine now thx all.... laugh.gif
