2.5" for an exhaust setup??!
Old Jan 29, 2005 | 01:58 PM
sharkev's Avatar
Default 2.5" for an exhaust setup??!
What you people think about this???.........
a 2.5" for a Automatic Beta 1??...... is this too large and it sould be better a 2.25??.........
for now I´m running N/A.... but I think that next month I will be running Turbo.... so what do you think??....
I will loose a lot of compression?? or not too much?........
Any idea of gains or lost in the power range???
thanks
Old Jan 29, 2005 | 02:01 PM
tanc's Avatar
Vehicle: 1997 Tiburon
if your going to boost, then 2.5 - 3 inch depending on what psi your going to be running. I'd recommend 2.5
Old Jan 29, 2005 | 02:38 PM
hamhead's Avatar
2.inch is fine. I don't know what your talking about compression... compression has nothing to do with exhaust. 2.5inch is fine for Naturally aspirated or mild-moderate turbo applications. I'm running 2.5inch on a N/A car and I lost no low end... the exhaust picks up around 3500-4000 is where you start to feel the power gain.
Old Jan 30, 2005 | 08:26 AM
CyberShark's Avatar
Get the 2.5, it will work fine for both turbo and N/A ...
Old Jan 31, 2005 | 06:11 PM
sharkev's Avatar
UPDATE!!!
I´ve just installed my 2.5 pipe................
so till now I havent ran hard...... but I supose It has to feel the power in the higher RPM right??
thanks
Old Jan 31, 2005 | 06:21 PM
hamhead's Avatar
Yeah, it'll be able to felt more middle-high.
Old Jan 31, 2005 | 06:25 PM
CyberShark's Avatar
Sounds mean..right?
Old Jan 31, 2005 | 07:43 PM
sharkev's Avatar
It didnt change the sound........... i thought that it was going to change, but no..........
I hope everything is ok........Lol......
Old Jan 31, 2005 | 08:04 PM
CyberShark's Avatar
Did you have a custom crush bend exhaust or did you buy an aftermarket exhaust?
Old Jan 31, 2005 | 08:06 PM
hamhead's Avatar
Did you keep the stock muffler?
