faulty alternator?
Old Feb 20, 2005 | 02:02 AM
tanc's Avatar
Vehicle: 1997 Tiburon
Default faulty alternator?
Sittin in the Mcdonalds drive through line, then I put my window up and when I hit the button the car start idling rough around 700 and my interior/exterior lights dim.
My battery is 690 amps I believe, and I've never replaced or tuned up the alternator so I have no idea what condition its in.
Old Feb 20, 2005 | 08:42 AM
if the lights and idle returned to normal after you let go of the switch.. I would not worry about it too much. Even when new, if I moved the windows at idle, you could watch the lights dim at night. Electric windows are just a BIG draw on power and at idle your alternator is not putting out all the juice if can.
Old Feb 20, 2005 | 08:50 AM
Alex01tib's Avatar
yah anytime something has to be moved and it is powered by an electric motor it draws a good amount of electricity; and the windows arent feathers so it takes even more.. Does the Big three wire upgrade help reduce this dimming effect?
Old Feb 20, 2005 | 09:00 AM
another thing to remember.. the fact that your engine idle dropped like that was a sign your alternator was working properly. It was trying to keep up with the electrical demand and was putting quite a drag on the engine.
Old Feb 20, 2005 | 10:04 AM
Alex01tib's Avatar
/ yup, should do that when you turn on the heat too
