Power Window Question
Old Apr 25, 2005 | 11:31 AM
emstib1's Avatar
Not sure if this is in the right thread.
I've been having a problem with my power window button. It's my drivers side. Sometimes it works, sometimes it doesnt. Anyone else have this problem?
Old Apr 25, 2005 | 12:07 PM
hamhead's Avatar
Tear the door panel off and find out. tongue.gif Make sure the wiring is ok and that the regulator still works. Those are the main problems that occur with windows.
Old Apr 25, 2005 | 12:12 PM
CyberShark's Avatar
I have a similiar problem but on the passenger side. Everyonce in a while, the window won't go down but if I turn off the car and restart it, it will roll down.
Old Apr 25, 2005 | 12:39 PM
hamhead's Avatar
Also for stupid people out there (like me) if the passenger window doesn't go down, make sure you have the window lock off. lol.gif To the eye, there isn't much difference between when its down or up.
Old Apr 25, 2005 | 01:14 PM
paperstsoapco's Avatar
<div class='quotetop'>QUOTE (CyberShark @ Apr 25 2005, 06:12 PM)</div><div class='quotemain'>I have a similiar problem but on the passenger side. Everyonce in a while, the window won't go down but if I turn off the car and restart it, it will roll down.
Same with me. Sometimes the drivers side window wont go back up, but usually if I turn the car off and back on again it'll work and go back up.
Old Apr 25, 2005 | 02:11 PM
DarkShark's Avatar
Same thing happens to me on occasions. Sometime the window decides to work and other times it doesn't. Not quite sure what causes it. Probably a loose fuse or something.
Old Apr 25, 2005 | 03:11 PM
'treezy's Avatar
<div class='quotetop'>QUOTE (emstib1 @ Apr 25 2005, 05:31 PM)</div><div class='quotemain'>Not sure if this is in the right thread.
Did you by chance ever take apart your window switch and remove the buttons?
If so, you have to put it back together preciseley the correct way for it to operate properly. Otherwise the button may not "catch" all the time, or others it will stick and stay down unless you press the button the opposite way to make it level.
If that's the case, I can show you how to put it back together. Each piece is NOT interchangeable. If not...check the wiring.
Old Apr 25, 2005 | 03:36 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
It's funn everyone has this problem. I had it frequently for a while then it just stopped happening.
Old Apr 25, 2005 | 08:42 PM
emstib1's Avatar
I had this problem before with the passenger side window expect it rolled up TOO far and would go over the seal! That was the regulator then, i wasnt sure if it would be the same for this.
Old Apr 25, 2005 | 10:19 PM
Casper's Avatar
<div class='quotetop'>QUOTE (CyberShark @ Apr 25 2005, 02:12 PM)</div><div class='quotemain'>I have a similiar problem but on the passenger side. Everyonce in a while, the window won't go down but if I turn off the car and restart it, it will roll down.
hrmm, I thats funny. Twice in the past year my Drivers side window wouldnt go back Up lol. Same thing... restart the car and it works.
