- Hyundai coupe 1996 wheel fitment
- Handling upgrades
- larger suspention
- 2017 Santa Fe SE AWD rear air shocks or spring assist
- Correct lowering springs
- Tire & Rim Calculator
- Best way to get cracked lug nut off
- Glossifier or matte?
- Why is this so expensive
- Whats a good tire inflater to get?
- brake dust
- Brake Fluid Comparisons
- What's with the black wheels trend?
- The truth about Rotiforms
- Megan Racing Coil Overs
- Nitto invo or nt555
- Tire Stickers
- Wheel Bearing Replacement
- X3 excel (accent) brake upgrade
- Your favorite spray wheel cleaner
- Rusty bleeder screws
- If you have knock off or fake wheels, how are they holding up?
- Bare minimum tread depth
- How long do your tires last?
- Fraud tires
- How many tires do you have laying around at home?
- Anyone use Gorilla lug nuts/locks?
- What can be done to prevent calipers from seizing?
- Who has colored wheels?
- Adding TPMS to cars that dont come equipped with it
- Claybaring wheels
- Good wheel sealant or coating
- Same camber front and rear
- Why replace rotors and not pads?
- What does everyone do with their snow tires when it's time to switch
- Raybestos brake pads falling apart
- Lug nuts and salt damage
- Who has these or had them at one time?
- Gold and black rotors
- Lighter wheels, how much of a difference do they make?
- Tire size for 19x11
- So low
- Can any wheel cleaner be used on matte black wheels?
- Happening Now
- Can chrome lips be repaired?
- What do you mostly look for when shopping for new wheels?
- How do you break in your new tires?
- Camber bolts for the front only
- Camber question
- Discount Tire gives 1 million to campaign against legalization of weed
- Drag Wheels Got Hacked
- Adjustable Sway Bar End Links
- Safe to claybar wheels with clear coat?
- growl when braking with new rotors & pads
- Buying brake parts from Rock Auto
- Checking lug nuts
- new wheel stud time
- Alignments
- Wheel weight adhesive issue
- Lowering spring
- Saw someone last night with these on their car
- 5mm wheel spacers
- Does powder coating wheels weaken them in any way?
- Front suspension question
- I'm Pretty Happy With My Car Right Now
- Nitto NT555
- Tires
- Duplicolor Tire Shine Coating
- EBC GreenStuff
- Bigger brakes
- Most effective suspension upgrade?
- Do you hate on people who have fake wheels?
- Subframe bushings
- Brake lights wont go off plz read
- Tires for my Elantra Hatch
- How much camber do you have on your car?
- That time of the year now
- Rota Slipstreams
- Clear Plasti Dip
- TIL There is as Ball Bearing on Top of Struts
- The Parking Brake
- Noise That I Cannot Figure Out
- Winter tires
- Tire Pyrometers
- Ball Joint Question
- Quick Wheel Question!
- Your choice of wheels and why?
- rake System Power Bleeder
- Tire Wear
- Brake temps, anybody measured right after track sessions?
- Are subframe bushings worth it?
- This is pissing me off now
- What happens if CV joints snap?
- Save your rims, buy the right tires
- Stuck valve stem caps
- Polish for wheels
- How to
- Ball joint or wheel bearing
- Is there such a thing as lightweight chrome rims?
- Choosing 14" rims but what else?
- PSA - Dont forget your hubcentric rings
- How many sets of wheels have you been through?
- Lets see some deep dish wheels
- Do I have to have to my TPMS rebuilt?
- how long can i use spare tire?
- Stainless Steel brake lines
- Accent Brake Experience Needed
- Need help finding new tires for these racing wheels
- Coilovers
- New wheels...AGAIN
- Coilover Installation Help please
- Anybody driving on 2 types of tires?
- Does your car handle better with a full tank of gas?
- Fullsize spare
- Anyone buy whiteline lca bushings? J2/RD
- Nitrogen for tire inflation at home?
- how do you know if your struts are shot?
- DIY: Lifting X3 suspension
- DIY: Replacing drum brake shoes
- Brake booster delete
- Picked up a new set of wheels
- Hankook's futuristic concept tires
- Default auto carbon fiber,you know this?
- Whats the longest youve gone between brake pad changes?
- Low rolling resistance tires
- Not a club I want to be apart of...
- Serious suspension question
- When are you guys putting your winter tires on?
- Winter Tires
- So I did my own alignment today . . .
- Sturts
- Big brakes
- Is this how run flats work?
- I want wheel spacers but I'm scared
- Do these make a huge difference in the way your car handles?
- Is it possible at all to do your own at home alignment?
- Can the US please adopt this law next please
- Help settle a bet
- Missing wear indicators
- Current tires
- Post your bronze wheels
- Cool Eibach Spring Video
- Sway link suspensions part
- Sway links
- What summer tire is everyone using?
- coilovers or new OEM
- Just being silly and vain
- -FACEPALM-
- Has anyone actually gotten their city to replace a blown out tire
- NEW 200TW Hoosier Street Tire!!!!
- 99 accent fully adjustable wrx suspension might work
- Would you buy carbon fiber wheels?
- New Wheels question
- Suspension Bushings: Full Replacement
- Stoptech Brakes
- Electric Power Steering
- need opinions on wheel colors (Plastidip)
- Are spacers unsafe to use?
- Water Transfer Printing
- rear brake upgrade for TIB 2000
- Rim question
- Is Porche the only company that makes weird colored wheels?
- Hydros vs Air Bags Car Fight
- Does Hyundai make their wheels?
- Should I spend the extra money on nitrogen filled tires?
- Sickest wheels ever
- When changing brake pads
- rear drum brake adjuster hole
- Interesting idea for shocks
- tire gauges
- Brake squeal?
- Opinion on these wheels
- cordless impact driver
- Air vs. Coilovers
- Wheel caps or no wheel caps?
- I think we all can agree on this one
- Tire Dressing For The Winter
- Help choosing tires
- Ocean City MD PD impounding cars with excessive camber
- wheels badly rubbing on rear (no money need them to work)
- Separating 3 piece volk wheels
- method of buying rims
- Patch or Plug
- Have you got over tightened lug nuts from a repair shop?
- When do you decide its time for new tires
- How much extra weight does chroming wheels add?
- Tuning your suspension
- New wheels for the Tib
- Best Budget Tire
- tire size
- ROTA Wheels warns against counterfeit products
- Front strut bar
- Strut bar - need purchasing advice
- Installing Performance Brakes
- Need help upgrading suspension
- Check that spare!
- wheel wax?
- Time to replace strut mounts?
- Wheel and tire package budget
- Ultra Racing chasis tuning?
- Tell Me Again How This Was A Good Idea?
- Advice for studs and wheel spacers
- Grease for sway bar bushings
- Hellaflushed Lambo
- When should you brake-check someone?
- Continental ExtremeContact DW
- Tire storage or rack
- Any body riding on forged wheels?
- Ksport install question.....
- Possible to turn your own rotors?
- Who has step lip wheels?
- powder coat, paint, or plasti dip?
- Dat Camber
- Can this fad just die already?
- Is load index important to you?
- Sway bar replacements
- Dat Stance
- Slime?
- New brake rotors, clean the oil off?
- Genesis wheels on a tib
- Which Coilover system to buy?!?
- always wear a rubber
- tire and wheel insurance
- Braided brake lines
- Hyundai trying to F*** Me Big time.
- POR-15. Anyone tried this stuff yet?
- Tire Rotation
- Strange brake problem over the weekend
- Replacing Front Wheel Bearings
- Wheel Sealant
- Looks like something some Gen Coupe members would do
- technical question about tire wear
- 1 broken spring..
- Hyundai suspension
- When to replace tires?
- Anyone using 17/18s on LC accent ?
- Hey bro, got stance?
- Quiet tires?
- Can you fit the factory 245/45/18 tires on a 9.5" wheel?
- Still makes me laugh every single time
- Anybody know what wheels these are?
- Need some better and more durable tires
- DIY Brake Pressure Bleeder?
- Painting my wheels need opions on paint
- What offset are your wheels?
- Over/understeer and reacting to them....
- 15-Series Tires
- Tiburon camber bolts
- Effects of Upsized Wheels and Tires Tested
- The Dangers of Replacing Coil Springs on Your Vehicle
