Tiburon camber bolts
Old Feb 7, 2013 | 04:43 PM
rx bandit's Avatar
Vehicle: 2000 Tiburon
Default Tiburon camber bolts
I have never heard of anyone having these on their Tibs but what do the suspension experts on HA think about them?
http://www.horsepowerfreaks.com/part...ber_Bolt/20537
Old Feb 7, 2013 | 05:54 PM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
I used them on the rear of my Tib, cause in the rear with ksports when you go low it messes up the geometry of the suspension and if you want to wear things evenly you will want a set for the rear or get pillowball top hats.
Old Feb 7, 2013 | 09:16 PM
wheel_of_steel's Avatar
They do the job, roughly though. Adjustable camber tops are better in a few ways, namely:
-you don't f*ck your alignment every time you change a CV joint
-far better suspension geometry, especially for the front
-camber tops are a lot stronger than skinny eBay bolts
I've got a pair on the front of my X3. They only cost $35, but they're not ideal.
