Stuck valve stem caps
Old Jun 14, 2015 | 04:12 PM
Carbonred's Avatar
Vehicle: 00 Tiburon
Default Stuck valve stem caps
One of my caps is stuck on my valve stems. I have metal caps and I think its rusted on the valve. Anyone know an easy way to get it off without damaging the valve and causing air to leak out of the tire?
Old Jun 14, 2015 | 10:10 PM
I would try letting it soak in *penetrating* oil for a couple of days, then give a few taps with the end of your pliers, then try to remove the stem. In the absolute worst case, you rip the stem, install your spare, and drive to a tire shop that will give you a new stem for like $5+labor.
