technical question about tire wear
Old Apr 15, 2013 | 12:43 PM
frogger's Avatar
Default technical question about tire wear
one of my tires needs replacing because the sidewall was damaged after passing over a deep pothole.
the tire shop insists i replace BOTH rear tires, even though there is only very minimal wear on the matching tire on the other side of the car (its less than 3 months old).
what do you guys think? replace both or just the one?
Old Apr 15, 2013 | 12:58 PM
replace just the one, it may pull to the side a bit though
now if its a drive axle tire, thats a different story
Old Apr 16, 2013 | 05:32 AM
Red Raspberry's Avatar
The right side will wear faster. If they aren't directional then swapping sides at the right time will equalize wear.
