Log in
View Full Version : Braking, Wheels, Tires, Suspension
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12
  1. coil over system
  2. Brake chirp
  3. winter tires final choice Questions
  4. Rim Weight question
  5. Confused on tire logic
  6. What are the wheels made of?
  7. Help me choose: Stock or New wheels *** w/Pix not links***
  8. I found my new rims!!
  9. Konig Unknown
  10. Spare Tire?
  11. Brakes
  12. Eibach from ebay
  13. what do you think about these?????
  14. NIPLEEEEEEEEESSSSSSSS
  15. rims help.. opinions
  16. BEST DAMN TIRES AROUND!!!!
  17. Drum to disc?
  18. Best Winter Tire
  19. Tire recomendation?
  20. Widest tire for our cars?
  21. **HELP** what is the caliper bolts size?
  22. to everyone with a veilside kit & suspension...
  23. Question for the Canadian PPL from around the GTA
  24. handling/ ride hight
  25. Noisy shocks...
  26. removing break Calipers
  27. which one should I choose~!??
  28. Doing your own struts?
  29. Wheel hub bearings questions
  30. Weird Tire Wear
  31. Rear strut bar
  32. Wheels Sites
  33. upgrading my brakes
  34. 17s?
  35. Another tire help topic!
  36. RD1 and RD2??????
  37. new rotorpros on
  38. anyone know anything about dean tires?
  39. Brake pad/references
  40. Tires
  41. Strut Bar (Front)
  42. SUPENSION BARS??
  43. Anti Roll Bar Question
  44. Camber Kits???
  45. Wheel choice advice...
  46. Quality of Motegi rims??? *how about these ones*
  47. Lower ball joint
  48. Tire squeel?
  49. I need a stiffer suspension!
  50. i want some coilovers!!
  51. Non-Captive Rotor Swap
  52. Wheel Spacer?
  53. transmission problem
  54. Opinions - Best Winter Tires
  55. Shims...how important?
  56. bent wheel
  57. Struts?
  58. Anyone heard of these brake pads?
  59. Rear Rotor
  60. Making my 97 1.8L Tib front non captive + rear captive DISC?
  61. Wheels...ebay...help!
  62. Lowering springs
  63. Warped rotors
  64. Installed intrax today :)
  65. All About Correct Tire Size And Wheel Offset - A M
  66. alignment and drifting
  67. GK tib brake upgrade !
  68. falken tire Problems
  69. Rough Ride When Braking
  70. new brakes squeak?
  71. Mussa strut bar
  72. adjusting parking brake?
  73. EBC Greenstuff
  74. Mussa Strut bar
  75. Calipers
  76. Strut Bars: Preload or No Load?
  77. Tire size Vs. Cornering capability
  78. direct bolt on air ride or hydros
  79. Different bolt patterns?
  80. need help with tires
  81. Front Rotors going away fast with EBC Greenstuff ???
  82. Help with rims
  83. P-zero Nero, or Parada spec 2?
  84. stocker tirer
  85. EiBach Camber Kits Question
  86. 19's on tib???
  87. strut tower bolts not lining up!!!!!
  88. Recalibrate The Speedo
  89. Screw in rear rotor?
  90. Enkei's fit?
  91. What tires should I get?
  92. EBAY rotors?
  93. AirRAm+Strutbar=DONE!!
  94. tires and brakes
  95. wheels alignment?
  96. Brake shims
  97. I NEED SERIOUS SUSPENSION HELP PLEEASSEE
  98. Help finding Reasons... Konig, that is...
  99. Springs and Struts?
  100. Front strut bar
  101. Falken Ziex ZE 512
  102. Brembo Sports Kit
  103. White 17's on my blue 01 Tib *PICS*
  104. possible rear sway bar group buy
  105. Miglia wheels?
  106. SS Brake lines
  107. 4-wheel alignment specs and rear wheels squealing! RD1
  108. Drilled/Slotted rotors
  109. New Enkei Rims
  110. Exel or Katana wheels?
  111. Center Bars, Door Bars, C Pillar Bars? Roof Bars?!?!?
  112. Will 235/45-17 fit?
  113. WANT A SSBC big brake kit?
  114. widest wheel possible??
  115. Rotor Question
  116. Looking for rims
  117. BFgoodrich Sorcher tires
  118. Basic wheel/tire facts everyone should know.
  119. Ouik stupid ?
  120. Who has Ground Control Coilovers on thier car
  121. Looking around at wheels. Have Q's
  122. Updated*Pics of my Bronze wheels** 56k warning
  123. Finally getting Rims & Tires
  124. brake question(s)
  125. Wheel size, offset
  126. These rims and tires
  127. Another "spacer" question
  128. How do I bleed brakes???
  129. Wheels wont move
  130. Kumho ecsta supra's
  131. wheel spacer
  132. Rotor(s) and Wheel Replacement
  133. Stock ride height
  134. 16" rims
  135. Stock wheel size and offset?
  136. Arospeed Adjustable Coilovers
  137. t and p gold series coilovers
  138. i want air!!!!!
  139. Will 225/40/18 rub w/factory suspension?
  140. Need help with Rear Body Shaking
  141. Gonna give my Tib a brake job
  142. Steering wheel shaking
  143. Loud Knock Sound From Front End Over Bumps
  144. Help
  145. Rims im going to buy(o)(o)
  146. Chromium Black?
  147. Which Enkei?
  148. *SPLIT* Wow, I got my strut bar, pics!
  149. *UPDATED 6/1* Which color wheels? *Rims are on*
  150. camber bolts
  151. help with a question plz
  152. Rims and breaks
  153. 01 Tibby rims on a 97
  154. Strut bar on
  155. New Rotors?
  156. Urgent - anyone know a good wheel place in florida
  157. Put Strut (BARS) in
  158. 205/45/17
  159. advice on tires...
  160. Alignment Questions
  161. Strut bar fitment for RD's and RD2's
  162. Replacing captive rotors bolts with flathead cap screws
  163. Springs and shocks
  164. Stock Strut question :)
  165. Review of Quest HR coilovers
  166. lightweights wheels
  167. look what I just picked up! (56k warning)
  168. Quote from April issue of SCC
  169. Rear strut bar install
  170. can anybody tell me wat these rims are!!
  171. rim size
  172. Rubbing?
  173. Racing rims with spinners?
  174. A couple of questions...
  175. Which rims? Please help.
  176. Sticky street tires
  177. 98 coilovers on a 97?
  178. best place to buy rotors...
  179. Debate: Coils or Springs
  180. B&G Coilover setup
  181. Steel Braided brake lines
  182. Kumho's
  183. Airride questions? (Split by Moderator)
  184. 17" rims
  185. 98 Tiburon bolt pattern
  186. I need some tires...
  187. why lower
  188. got my new tyres
  189. Strut bar
  190. 18" rims
  191. 205/45/17???????????
  192. -1.6 front and -1.5 front drop, what wheels would fit ?
  193. brake rotors
  194. Anyone try Semperit Sportgrips?
  195. wheel off set for 2.5 inch drop
  196. will these fit?
  197. Wheel Offset Calculator
  198. pics of 16s with 45 series tires???
  199. Painting Calipers
  200. Brake noise!!! Help Cheryl!!!
  201. Ebay Item: OBX Camber kits
  202. Early Tib brake kits
  203. Camber Bolts
  204. Got new Winter Tires
  205. Brakes Rusting?
  206. Roll bar
  207. My Air Suspension FAQ
  208. Hydraulics 101 FAQ
  209. just got new toys
  210. suspension upgrade?
  211. New upgraded brake options!
  212. cool website
  213. Think these rims go good on a Tiburon?
  214. Eibach handling
  215. Improving handling & performance
  216. Just for kicks
  217. In the market for new wheels....
  218. Breaking distance
  219. Available aftermarket suspension components-Update 20May04
  220. Goodridge Brake Lines? Maybe...
  221. Best Budget Lowering Springs
  222. Performance Pads
  223. wanting fromt & rear rotors?
  224. 19's..Bags or coils?
  225. Spring "boosters"
  226. SR Hydraulic Suspension System (big pics)
  227. heating stock springs to lower car
  228. Rear springs are still not settled!!
  229. Whiteline bars
  230. Help removing rotor
  231. Some brake upgrade questions
  232. New 2003 Accent LC2
  233. buying tires finally... need your expert advise
  234. 18 in wheels
  235. Hawk pads
  236. H&R
  237. lug size??????
  238. Question about my Eibach springs...
  239. lowering the car
  240. Yet another captive rotor question
  241. Rotor bolts
  242. Brembo Brake Rotors...
  243. My new wheels and suspension
  244. a dumb question about rotors
  245. KORE V6 Ft Strut bar brackets fixed
  246. Uh, dumb question about brake pads
  247. 16's on a 2001 Tibby
  248. Tiburon struts
  249. Ground Control Coilovers
  250. Question about Eibach springs...
