Log in
View Full Version : Braking, Wheels, Tires, Suspension
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12
  1. The End of Tire Camber Woes?
  2. what's the best place to order tires from?
  3. All wheels have the ability to break, crack, and bend
  4. Can wheels be hard anodized?
  5. I'm kinda of digging these
  6. My Suspension!! My Poor Suspension!!!
  7. The future of tire design
  8. Cooper Zeon Tires
  9. J2 14x5.5 Alloy wheel weight?
  10. Wheel Hangers
  11. Which Hyundai do you think handles the best?
  12. Spider cracks in cross drilled rotors
  13. Replica wheels
  14. How do wheel spacers affect handling?
  15. Run Flats
  16. Springs or Coilovers???
  17. Ok to use impact wrench on lug bolts?
  18. Plasti dip clearcoat
  19. Fake wheels...haha
  20. Uh huh! Oh ya! me loves you long time
  21. wheel brush recomendation
  22. I like purple rims
  23. Do you drive with your spare tire in the car?
  24. Self inflating tires
  25. Favorite color combos
  26. Anodized stock rims
  27. How long does Plasti-dip last on wheels before peeling/nicking?
  28. Need tire suggestions
  29. 19's in the front, 20's in the back
  30. Nitto 555's
  31. Cheap snowtires now or quality all seasons
  32. Upgrading an Airbag Suspension?
  33. Camber Gauge
  34. beta swap- new suspension required ?
  35. Neon color rims
  36. Shaking Steering wheel question
  37. Do heavy wheels make the ride smoother?
  38. Genesis Sedan Wheels on an Azera?
  39. Kevlar or SS braided brake lines?
  40. Eibach Vs H&R Sway / Anti-roll Bars
  41. Knockoff wheels
  42. Painting rims body color
  43. Veloster rear suspension
  44. Staggered fitment on FWD cars
  45. These are kind of cool
  46. Am I alone in thinking this?
  47. captive brake rotors advice needed
  48. Has anyone shipped wheels and tires with the USPS
  49. XG350 brake upgrade issues
  50. Are these rotors ok to use?
  51. Ceramic Brake Discs (Brembo) "How It's Made"
  52. Lil drop on the V
  53. Need advice on size tires to use!
  54. White rims on a black genesis
  55. Open Ended Wheel Studs
  56. Shaving down brake caliper for clearance reasons.
  57. An Image Guide To Stance
  58. Tires? Who needs tires?
  59. 00-05 Accent Rear Disc Brake Swap Brackets
  60. Who has the highest stock clutch milage?
  61. TSW Nurburgring wheels
  62. What do you use to clean plastidip?
  63. Grinding Noise When I Reverse
  64. How to properly polish/clean clearcoated wheels?
  65. My lowered Genesis on Tein springs
  66. xg350/spectra RD2 BBK
  67. Next Saturday FOR A FACT!!!
  68. Official Ridiculous Color Wheel Thread
  69. Widening a wheel?
  70. OEM rims from other vehicles
  71. clutch question
  72. will this rim fit?
  73. Megan Racing or H&R coil overs
  74. 17" rims on an accent
  75. Tire sidewall question
  76. Best way to rotate tires without jack stands
  77. Wheel Restore Self Etching Primer
  78. Struts or Springs
  79. 96-00 elantra sedan rear struts vs wagon
  80. Good article for the Rota fan boys to read
  81. Bought new rims
  82. Plastidipping brake calipers
  83. Help me pick out new tires
  84. Road Hazard Warranty
  85. What are your thoughts on buying used suspension parts?
  86. How would these look
  87. Brake Upgrade Help (UK)
  88. NHTSA Wants To Break Your Heel-Toe Braking!
  89. Stripping wheel paint
  90. Free Black Magic Tire Shine
  91. New Hankook tires out for racers
  92. What would make lowering springs > coil overs
  93. Hawk pads with OEM blank rotors
  94. HRE rims on a Genesis
  95. Black wheels - I don't get it
  96. FINALLY got myself some coilovers
  97. Caliper slide pins
  98. Looking to buy a brake bleeder kit...any suggestions
  99. Bent rim
  100. Gold plastidip
  101. Theoretically
  102. Black chrome rims
  103. Do you wax your rims?
  104. Can you adjust koni shocks with the car on the ground
  105. Alignment shops
  106. Fog light brake ducts
  107. Blade rims
  108. White lugnuts
  109. Genesis rims on a GK
  110. adjustable struts and shocks
  111. Drilled rotors = cracking?
  112. Stainless steel lug nuts
  113. Tire stretching
  114. Buying used tires
  115. Skinny race tires
  116. Painted wheels
  117. Do dampers affect spring rates?
  118. Valve caps
  119. Metal on metal sound
  120. Wheel making
  121. Coilover cleaning
  122. Reputable rim brands
  123. Rim clear coat
  124. How NOT to lower your car
  125. Do you measure and calculate your own backspacing
  126. Sway bar stiffness
  127. How do you convert kg/m to spring constant k?
  128. Brake pads and outside temps
  129. Rear passenger wheel rubbing noise
  130. Are SACHS struts any good???
  131. Air Ride?
  132. best sway bars on lc?
  133. Mickey Thompson Street Radial Drag Tires
  134. 3" backspacing good for x3??
  135. toe in and toe out
  136. Wheel balancing
  137. Stiffer rigidity
  138. Being too low can be a bad thing
  139. Did your GR-2's get harsh when it got cold?
  140. Tire Valve Cap Problem
  141. Nankang Tires
  142. Traction
  143. Overtightening lug nuts
  144. simultaneous braking
  145. Alignment question
  146. Alignment and wheel bearings
  147. Coefficient of Drag & Lowering
  148. Should I toss them or not?
  149. Anodizing or powdercoating?
  150. Pot hole season has begun
  151. Is it worth it to have cross drilled rotors in the rear?
  152. Those with H&R, does the rear bottom out?
  153. Pressure Testing Calipers?
  154. Question about 'machined lips'
  155. caliper seizing
  156. Powdercoating drop springs
  157. Drilled rotor direction
  158. Will snow and ice ruin the finish on aftermarket rims?
  159. Ever had a boot put on your car?
  160. What speed rating do your tires have?
  161. Did you buy a 5th rim & tire for a spare?
  162. How long can I drive with warped rotors? What other damage can I incur?
  163. Can someone lend me alot of money?
  164. Plugged tire
  165. What size spacers to go flush in the rear
  166. Wheel Hop
  167. NT03+M Enkei's
  168. American Racing
  169. Cutting one coil out of springs
  170. Power Steering Delete
  171. Cryo rotor experiences
  172. Chassis foaming
  173. Cheap alternatives to TE-37's
  174. Alignment question
  175. The next ricer fad?
  176. Brake dust on inside of wheel
  177. Low profile tires in the snow
  178. OEM brake pads
  179. This is really getting out of hand now
  180. Question about All Season tires
  181. Do higher spring rates affect shock life?
  182. Staggered Wheels
  183. Snow packed rims
  184. Has anyone tried the Koni inserts?
  185. ABS overview
  186. PROS/CONS to Static Balancing over Sticky wheel wieghts?
  187. This is what happens when you buy cheap wheels
  188. Police are starting to ticket for stretched tires
  189. Mushy brake pedal after installing new pads
  190. Megan Racing coilovers, should I?
  191. Proper wheel tightening procedure...
  192. Anyone here ever had their car corner balanced?
  193. Wheel refinishing
  194. Whats your winter tire setup?
  195. Rotor question
  196. Helical or straight cut gears?
  197. Thoughts on B&G springs..
  198. 2 piece rotors?
  199. Thinking I may buy a BBK
  200. Load Index = pothole protection?
  201. help?! sway bar noise?
  202. Driving with Camber
  203. In your opinions, are Volk TE37's worth the price?
  204. Oversteer
  205. Black Magic Tire Tint??
  206. Lightweight lugnuts - unexpected issues?
  207. Tread Measurement... Penny vs. Actual Gauge
  208. This one is a head scratcher
  209. Nasty bump steer after installing H&R springs
  210. will these used tires fit?
  211. Saw stretched tires explode on the road today
  212. Brake rotors
  213. so is it safe to say that Ksports are quality coilovers?
  214. Brand new H&R springs are squeeking
  215. Brake Dust Cover/ Dust Shield
  216. H&R or Eibach springs?
  217. Sweet Brakes/Braking Troubleshooting Chart
  218. Question about brakes!
  219. Do our cars comes with bumpstops?
  220. Winter driving with coil overs
  221. Having a set of one off wheels made
  222. Alot of horsepower means NOTHING
  223. Inner Tie Rod Question
  224. looking to run a 17x8 with a 245 tire
  225. Do tire size and profile make a difference when driving in the snow?
  226. It really sucks not having air tools for this reason
  227. Painting Calipers: Some Questions
  228. Smoking brakes
  229. what kills struts, ride height or spring rates?
  230. Any BBS wheel owners?
  231. This vibration is driving me crazy
  232. Alignment after lowering car
  233. Booya! New rims for my Revision A
  234. TireDB
  235. GK springs on an RD?
  236. Not keeping brake pads the same
  237. Which Wheels for the Genesis
  238. 5 lug conversion on a x3?
  239. 5 lug conversion
  240. What does it cost to have rims powdercoated?
  241. Resurfacing slotted rotors
  242. 17x8 rims
  243. I love flat black rims
  244. What do these do?
  245. 10mm or 20mm spacers
  246. Will auto-xing wear out your tie rods?
  247. GC rims on a GK
  248. Best Aluminum Lug Nut For The Price
  249. brake squeel
  250. Increasing downforce on the front
