J2 14x5.5 Alloy wheel weight?
Old Dec 19, 2012 | 06:10 PM
2000J25SP's Avatar
Vehicle: 2000 Hyundai Elantra GLS
Default J2 14x5.5 Alloy wheel weight?
Does anyone know the weight of the 14x5.5 Alloys that were optional on 99-00 Elantras?
Old Dec 20, 2012 | 06:34 AM
Tak82's Avatar
Vehicle: 1997 RD 4-door
most hyundai alloys are a bit porky, probably for durability reasons,
they might range from 18-22 pounds.
Old Dec 20, 2012 | 02:26 PM
2000J25SP's Avatar
Damn that's heavy. I read that the steelies are 14.5 lbs, is that correct?
I'm considering buying the alloys from a junk yard. But I won't if they're that heavy. My car has a hard enough time trying to keep up with traffic as it is.
Old Dec 20, 2012 | 03:52 PM
Tak82's Avatar
keep in mind that the J2 GL elantra's wear 175-65-14s as standard fitment..so it's steelies are different width from the J2 GLS. GL steelies are 14x5, GLS steelies are 14x5.5 and wear 195-60-14 as standard fitment
other than that..they are identical 4x114 lug pattern with a 67.1mm hub bore, same as the x3 and ef sonata, gk, rd and many other hyundai's.
Old Dec 20, 2012 | 04:31 PM
2000J25SP's Avatar
99-00 J2s come standard with 195/60/14s with both the steelie and alloy. They are both 14x5.5
Old Dec 21, 2012 | 08:17 AM
Tak82's Avatar
my mistake..my early model j2 has the 14x5 wheels,
i guess the 99-00 elantras did away with the 14x5's...oh well, the 14x5 with the 175-65-14 fitment is lighter and acceleration and steering is light but great.
you may wanna try some mitsubishi wheels, like the early lancer or mirage or colt wheels, the alloys are lighter than the hyundai wheels.
Old Dec 21, 2012 | 09:27 AM
2000J25SP's Avatar
Thanks!!! I forgot about the old Mitsu wheels being the same 114.3 and 67.1 hub bore.
