Log in
View Full Version : Braking, Wheels, Tires, Suspension
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12
  1. H&r Coil Over Issues
  2. I Need A Measurement From A Volunteer....
  3. What Do I Need
  4. This Car Is So Darn Odd
  5. I'm Having No Luck Finding A Rim Or Tires
  6. Question
  7. Price Check Ilse 7, Wheel Bearing
  8. I <3 Tirerack
  9. My Xg350 Brake Upgrade
  10. Adr Wheels
  11. New Struts Are In
  12. Picking New Rims + Poll ! (fixed)
  13. Choosing Rims (poll !)
  14. Lower Just Front End?
  15. Need Help With New Rims
  16. Rear-end Slides Out While Cornering
  17. Rear Brake Problem
  18. Breaks Screaping/grinding Sound?
  19. Captive Or Noncaptive
  20. Looking For The Stiffest Spring Possible
  21. Looking For Veilside Andrew Racing V 19"
  22. What Rims Are These?
  23. I Want To Buy Eibach Springs
  24. Wheel Bearing Torque?
  25. Rim Paint
  26. Replacing Front Rotors.
  27. One Upgrade At A Time
  28. Caliper Differences
  29. Best Place To Purchase Eibach Parts From?
  30. Quick Question About Hub
  31. Wheel Center Mah-bob
  32. Center Caps...help
  33. After Accident, One Side Sits
  34. God Damn Garage
  35. Right Wheel Noise
  36. Better Sway Bar Links? What Are Your Sugggestions?
  37. Brake Upgrade
  38. Steering Wheel Shaking?
  39. Replacing Brake Pads And Rotors,
  40. Just Did Rear Brake Pads Myself
  41. My New Nex Coilovers Help!
  42. Best Aftermarket Brakes For The Tibs?
  43. New Tires, Anyone Familiar With Either Of These?
  44. Bigger Rear Sway Bar
  45. Kyb Agx Vs Kyb Gr2
  46. Help! Who Has Completed The 5-lug Conversion?
  47. Damage From The Accident..
  48. Pulsing While Breaking
  49. Can Anyone Guess What Im Getting Ready To Do.....lol
  50. Eibach Damper Vs Kyb Gr2 Struts/shocks
  51. F*ing Ice On The Roads .. Crash
  52. Nex Coilovers
  53. Lower The Tib
  54. Wheel Spacers... How Thick Can I Go Without Problems
  55. Ebc Green Stuff
  56. Brake Problem
  57. Noise: Struts Or Tie Rods?
  58. Ebay Rotors
  59. I Need Someone To Look At Their Brake Pedal For Me...
  60. End Link Measurements?
  61. E Brake
  62. I Believe I Am Going To Be The Second One.
  63. Eibach Suspension
  64. Will Ksport (or Other) Pillow Ball Mounts Fit With A Different Brand Coilover?
  65. Best Hard Street Use Pads, Bbk?
  66. Looking Into Slicks
  67. Is It Time For Shocks And Struts?
  68. 5spd Swap Complete! - Brake Lights Don't Work!
  69. Loose Steering
  70. Want Some Cheap Arp Wheel Studs?
  71. E-brake Seizing, Replaced Rear Calipers
  72. Shopping For Lugnuts
  73. Will This Work For The Front?
  74. Nexen N3000 Tires
  75. Noise/rubbing Sound
  76. Quick ?
  77. Wheel Weight Listing
  78. Noisy Wheel
  79. Motegi Trak Lites
  80. Edfc In A Rd Ttib?! Yijoo Members, Come In!
  81. Deestibo's Rotors And Pads
  82. Unlower My Tib
  83. Wheel Hop?
  84. Intrax Spring Question
  85. Constant Humming From Wheels (mayb)
  86. Rim Weights...
  87. Five Lug
  88. Ebay Alert..help With Shocks?
  89. Tire Question
  90. What To Do With Old Tires?
  91. Suspension Problem
  92. Will 65 Series Tire Rub?
  93. Wider Front Tires. How Much Wider?
  94. "why Wheels Are More Than Just The Tire Holders"
  95. Sway Bar Hitting My Control Arms.
  96. What Size Of Rims And Tires You Runnin?
  97. Wheel Weight...
  98. Theres A Bird In My Brakes
  99. My New Badass Air Ram Strut Bar..
  100. Working For Energy Suspension
  101. Stock Lug Nuts Specs
  102. Santa Fe Rims?
  103. Hopefully An Easy Problem
  104. Finally, Real Rims!
  105. How About These Under My Tibby?
  106. Polised Looking Rims
  107. What Do You Think About These?
  108. Captive Rotor Rim Options
  109. Ebay Coilovers/springs
  110. Springs And Rims
  111. Direction
  112. Vibration Problem
  113. *new* Nex Suspension Dirt Cheap!
  114. About Ksport Coilobers...
  115. Time To Get New 17" Wheels...
  116. G4 Racing Coil-overs... Know Them?
  117. 2006 Tiburon 4-abs Brakes
  118. 4 Piston Brake Caliper Bbk
  119. Suspension Suggestions
  120. I Need A Link To A Shock Install Diy
  121. New Tires
  122. 03 Sante Fa Front Calipres On A Tib? Rd1? Rd2?
  123. Problems... What Could It Be This Time?
  124. Need Help With Tiburon Rim Size.
  125. Captive To Non-captive
  126. Ball Joint-lower Arm Removal..
  127. Looking For Affordable Rims
  128. Replacment Peices For Ksport Coilovers?
  129. Quick Brake Question
  130. 18"yes Or No
  131. Springs And Struts Install
  132. Brake Rotors
  133. Tenzo R
  134. Rotors
  135. Boss Brakes
  136. Lowering Springs
  137. Screws On The Rotors
  138. Knock Problem With My Tibby
  139. Screeching Noise --> Rims Scratched!
  140. Rear Sway Bars ?
  141. Whats Available In Rd1 Aftermarket Suspension On A Budget In Canada?
  142. Used Tires....
  143. Signs Of A New Master Cylinder
  144. Phorq Has New Shoes
  145. New Brake System
  146. Ebc Rotors
  147. How Low Can You Go?
  148. Eibach Install Advice?
  149. Wtf Brake Lights!?
  150. Rear-left Caliper Dragging....skrreeeeeeee!
  151. Power Steering Belt Part Number?
  152. Goodridge Ss Brake Lines
  153. Yet Another Xg Caliper Question!
  154. What Happens When You're Low On Steering Fluid?
  155. Brake Rubbing (now Scraping) When Not Braking
  156. Brakes Squeeling
  157. Clicking While Driving
  158. Diagnosing Loose Suspension
  159. Vibrations 60 Mph +
  160. Help Me Decide
  161. Which Aftermarket Brakes Do Tib Owners Perfer?
  162. Slick Size
  163. Help Me Decide!
  164. Replacing Front Tires
  165. Warped Rotor Question And E-brake Question
  166. Replaced Break Pads Strange *knock*
  167. I Need New Springs With Stock Height
  168. Master Cylinder Upgrade
  169. Never Seen This Before
  170. Bilstein Struts Any Good?
  171. Big Brake Kits
  172. Staggered Rims On A Ff Car *read Up*
  173. Need Opinion From You Guys...
  174. What Tires Do You Recomend?
  175. Brakes Squealing Like A Mofo!
  176. Brakes, Suspension, Tires And Rims
  177. Parking Brake?!
  178. Rd 4stud To 5stud Gk Hubs Possible?
  179. Ordering New Rims
  180. Gram Lights 57c (gold) W/eagle F1 Tires
  181. J2 With Eibach Pro Kit
  182. Eibach Pro Kit
  183. Grinding Noise When Turning And Driving
  184. Stock Rims And Tires
  185. Suspension Springs
  186. Suspension 1999 Tib
  187. Rear Hub Assy Replacement Question
  188. My New Rims And Tires (pix)
  189. Cross Drilled Rotors
  190. Will These Rims And Tires Fit?
  191. Resurfacing The Rotors.
  192. Vibration!
  193. Rear Caliper Seize
  194. Weird "whistle" Coming From Rear
  195. Any Good Ideas?
  196. EXTREMELY cheap coil overs on ebay....
  197. Those Of You With Springs!
  198. Installing The Eibach Pro Kit
  199. Wrong Wheels!
  200. Which Wheel Is Better?
  201. What Do You Think Of These Wheels?
  202. Best Bet
  203. Lowering A 2001 Tib
  204. 2.0 Gk Bushing Set From Kspec Work For Rd2?
  205. Help With Rear Chamber Kit
  206. Suspension Help/advice
  207. 97 Calipers Dont Fit With New Non Capt. Hubs
  208. Noobie Needs Drop
  209. Stock Spring Height But Aftermarket
  210. Gauging Interest In Rd Tiburon Performance Springs
  211. Horrible Road Noise
  212. Wheel/tire Suggestions?
  213. Problem With Brakes
  214. Reducing Body Roll
  215. Sounds Like Suspension
  216. Tire Question
  217. Need New Rims
  218. Ss Brake Lines
  219. Removing Captive Rotor Bolts
  220. Kyb Agx
  221. Differences In Intrax
  222. Brake Or Wheel Bearing Issue?
  223. It Works! 11inch Bbk
  224. Pirelli "dragons"
  225. Tubular Arms
  226. How To Read Abs Error Code
  227. How To Change Drum Brake Shoes?
  228. Coilovers
  229. Anyone Using These Coilovers?
  230. Air Bags
  231. Calipers Are Stuck
  232. Stock Rd2 Springs Lower Then Stock Rd1?
  233. Hard Braking = Grinding Sound
  234. How To Stop Rear End From Sinking
  235. Light Weight Wheels And Tires.
  236. Have You Owned Kyb Gr2 ~and~ Eibach Struts?
  237. Suspension Recommendation
  238. Replacing Brake Pads
  239. Obx Camber Kit Questions
  240. Stupid Swaybar Links :(
  241. New Noise -failing Strut?
  242. Rear Drum Brake To Disc Brake Conversion?
  243. My Front Rotors.
  244. Stabilizer Sway Bars
  245. AIR RIDE FOR A (99) TIB
  246. Will these bad boy tires fit?
  247. D/s Rotors & New Pads - Rear Tires Lock Up First?
  248. Front Spindles On X3 Accent = Rd Tiburon?
  249. Arospeed Adjustable Coilovers
  250. Sharkracing big brake kit ver. 1
