Rear Brake Problem
I drove my car today for the first time in about a week and now the right rear caliper won't fully disengage.
1. Does anyone know how we can lubricate the sliders?
2. What else could be wrong? All other 3 tires spin without effort.
ok ill elaborate. my car was perfect a week ago, its has done nothing but sit. The ebrake works just fine and i already wore off all of the rust. I think my sliders/guides are rusty and i don't know how/where to lube them or what the underlying problem could be otherwise.
The guides are a PITA if you live in an area that sees salt on the roads. I had one of mine sieze but did not know until I replaced the rear pads and could not get the caliper to seat properly..
What you need to do is take the wheel off and remove the caliper from the mount. The Slides are the backside of the bolts that hold the calipers on.
I had the same problem, it's the main cilinder within the caliper, I don't know the name, it's an unexpensive part, but I had to get it changed at the dealer because I am not handy when it comes to brakes. They rust, it's not uncommon.
