New Noise -failing Strut?
Old Apr 27, 2006 | 11:11 PM
Screwdriver's Avatar
If you read my previous post about my leaking caliper, you'll be interested to know that yet another noise has emerged from my driver's side wheel well.
It sounds like a thud noise everytime the road gets rough/ uneven. Sounds softer than a fully failed strut on my friends car.
Two observations:
1) Began only after I replaced the caliper and bled the lines
2) Doesn't seem to "thud" when I brake. Could be wrong but I tried to gently brake over bad roads to see if it would make the same noise.
Once again, the noise kinda sounds like a quick "Thud thud thud" evertime the road gets uneven.
Is this a failed strut? Any other indicators?
Old Apr 27, 2006 | 11:18 PM
SilentSecret's Avatar
Vehicle: 1997 Hyundai Tiburon
im guessin its failing struts i have them too. sounds like the bumps are amplified 10x inside the car. its on the passenger side too rite?
Old Apr 28, 2006 | 10:37 AM
Could it be brake related?
I can't believe HOW many problems I've had with this one driver's side wheel well.
Old Apr 28, 2006 | 01:46 PM
JonGTR's Avatar
I've had that problem for a while now too. Started around 55k miles.
It thuds on the driver side when I take off. So I guess when the strut expands.
