New Noise -failing Strut?
If you read my previous post about my leaking caliper, you'll be interested to know that yet another noise has emerged from my driver's side wheel well.
It sounds like a thud noise everytime the road gets rough/ uneven. Sounds softer than a fully failed strut on my friends car.
Two observations:
1) Began only after I replaced the caliper and bled the lines
2) Doesn't seem to "thud" when I brake. Could be wrong but I tried to gently brake over bad roads to see if it would make the same noise.
Once again, the noise kinda sounds like a quick "Thud thud thud" evertime the road gets uneven.
Is this a failed strut? Any other indicators?
Two observations:
I've had that problem for a while now too. Started around 55k miles.
It thuds on the driver side when I take off. So I guess when the strut expands.
