Tire Question
Old May 25, 2006 | 07:52 AM
i wanna run a 225/50/15 tire (i know this sounds rather noob....sorry) and dont wanna rub
its gonna be a hard task i know
what do you think i can do to allow that
ive thought about cutting off the flares that are on the volkswagen passat i think it is and molding it in but im unsure as to how that would look
i know coilovers will allow a wider tire cuz you dont have such a wide suspension body like struts do
any ideas?
Old May 25, 2006 | 04:41 PM
kb5133's Avatar
I'm running 205 50 KDW2s on 17's. My bad!!! 50 series is a little too big with 17's. Required some trimming of the fender guard and some "persuasion" on the fender lips with a rubber mallet. Minimal rubbing. Fender flares would be the way to go if I weren't so damn cheap.
Old May 25, 2006 | 04:51 PM
mang thats with 17s though no way in hell am i gonna run 17s
15s!!!
Old May 25, 2006 | 05:38 PM
kb5133's Avatar
That's what I'm sayin'. You should be good with a 50 series on 15s even at 225. Stockers were 50's and then don't even come close to the fender (I know, only 195's but still). I depends on the tire too. Even though the shop where I got the tires from said there wouldn't be much diff. between the 40 and 50. The difference between a 40series Yoko and a 50 series KDW are literally huge.
Old May 25, 2006 | 07:02 PM
there is a huge difference between 45 and 50 i can imagine the difference between 40 and 50
anyways
i guess ill have to give it a try....hopefully it wont stick out so much though ugh like those nasty daytons...
Old May 25, 2006 | 07:29 PM
You've prolly already checked this but here are the comparative specs, just in case fing02.gif
Old May 25, 2006 | 07:34 PM
hmmm its only a little more than a inch wider...hmmm interesting ill have to keep that in mind...
Old May 25, 2006 | 07:35 PM
hamhead's Avatar
Lemme know whats the biggest tire you can cram under there, I wanna put some big rubber under there myself. tongue.gif
Old May 25, 2006 | 07:41 PM
i wanna stick the widest possible tire without having it stick out of the fender no mojo for me!!! time to bust out the ruler...
Old May 25, 2006 | 07:52 PM
Just putting wider tyres won't necessarily mean more grip. If they are just cheaper hard-compound tyres, they won't do any good at all.
Also, I once read that something about the contact patch of the tire being affected primarily by load & psi... Not so much by it's tread width.
Not sure why that was but it made sense to me at the time. I'll see if I can find the article.
