Screws On The Rotors
Old Sep 11, 2006 | 05:05 PM
nate704's Avatar
I CAN NOT get it out~!!!
I tried with my screw driver and I just can't break it loose.
Any suggestion?
Should I have to take it to the shop?
What's the reasonable price for that?
Please help me out.
THanx in advance.
nate
Old Sep 11, 2006 | 05:08 PM
please fill in your profile to include location and year of tib
it helps when tryin to diagnose
Old Sep 11, 2006 | 05:23 PM
Sparticus's Avatar
Vehicle: 97 Tiburon
use an impact driver
Old Sep 11, 2006 | 06:15 PM
^yep! if not ive used a screwdriver with a vise grips at the end. you should be able to get it jsut be careful not to strip the head
Old Sep 11, 2006 | 07:29 PM
KustomizedTiburon's Avatar
Haha I had this problem right after I had my old chrome rims put on, I didn't realize it at first because of the low speeds but some lady pulled me over and said it looked like my wheel was going to fall off... The guys at the shop were embarassed as hell that they missed that... Theyre lucky no damage was done... I saw them just take a screwdriver to it but that was after a wheel was pushed out on it.
Old Sep 11, 2006 | 07:31 PM
Old Sep 11, 2006 | 07:43 PM
i think he's talking about the captive screw on the non captive rotors. Grab it with vice grips and twist that suxor off there. You can also cut a flat tip into it with a hack saw.
Old Sep 11, 2006 | 09:37 PM
hprockets's Avatar
Vehicle: 2009 Hyundai Sonata
hmm i used a cordless impact driver and it came off very easy.
perhaps use a larger screw driver? or rent an impact driver??
Old Sep 11, 2006 | 10:09 PM
Captives are BOLTs. There are 2 screws in the face of each rotor for help during assembly. If the phillips screws won't come out, just chisel the heads off.
Old Sep 11, 2006 | 10:45 PM
Alex01tib's Avatar
i had this problem, just get a disc sanding adapter for drill (~10 bux at walmart) and grind it off, easier IMO, and i happened to have the sanding discs laying around.
