Log in
View Full Version : Braking, Wheels, Tires, Suspension
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12
  1. Sway Bar End Links
  2. Abs And Handbrake Lights
  3. Who Has Used This Coilover Set-up On A Tib Or Other.
  4. check this out..crazy and awesome!!
  5. Firestone Vs Hyundai
  6. Rota Circuit 8 - How To Read Garble On Back Of Wheel
  7. Ebay Shocks And Springs
  8. Odd Vibration
  9. Anybody Have Experience With Msw Type 11 17" Wheels?
  10. Help Me Find 16x8/9 Wheels!
  11. I'm Going To Cut The Springs. Cutting Coil Springs.
  12. Painting Rusted Calipers
  13. Largest tire size on LC2
  14. Power Steering Pump
  15. Need New Struts for Accent X3
  16. Help! Weird Noise
  17. Rim Opinions(photoshop)
  18. Squeaking Noise
  19. New Rotors, Pads, And Lines Today(opinions)
  20. back bottoms out
  21. need advice
  22. Eibach Springs With Kyb-gr2 Struts
  23. Eibach Springs With Kyb-gr2 Struts
  24. Possable upgrades (LC with RD/RD2 or XG300 combo)
  25. Stubborn Rotors
  26. Chamber bolt for the Accent
  27. Full Urathane Yaya Kit: Feedback
  28. Clunk Noise With Coilovers
  29. Help! Rear Brake Pad Install Problem!
  30. Coilover Choice
  31. Which Lowering Springs?
  32. Brake Noise After 60km/hr
  33. Push Button Parking Brake
  34. Spacers... Does Thin Mean I Can't Use Duel 4 Lug Wheels?
  35. So Look At What I've Been Working On This Summer
  36. Brake Pad Suggestions?
  37. Tires Older Than 4 Years
  38. Loose/ Ill-functioning E-brake?
  39. Tire Wear
  40. Wich Wheels Will Fill My Fender Flare?
  41. Suspension Going :( Need Some Advice
  42. Rolling Inertia Calculator?
  43. new rims, now what tires?
  44. Nitrogen
  45. New Wheels On My Tibby!
  46. Another Wheel Topic...
  47. Caliper Question.
  48. Question Regarding Drum To Disk Swap
  49. Synthetic Brake And Clutch Oil
  50. Steering Wheel Wobbie
  51. Confusing Clunk
  52. Time For New Tires!
  53. Adjusting E-brake
  54. Strange Squeak
  55. Power Steering To Manual
  56. How To Install My New Ksport / D2 Coilover
  57. Wheels, Which Ones Should I Get?
  58. Slotted And Drilled Rotors (noise)
  59. Tire Fit To Wheels?
  60. Question About Wheel Spacers
  61. Clicking Sound
  62. You Need To Check Out My Car Now.
  63. Suspension/Alignment settings
  64. So Once Again, My Car Is A Death Trap...
  65. End Links
  66. Suspension Noise
  67. Gold Wheels
  68. Wobble Problem After Wheel Ebaring Replacment.
  69. Tire Fitment Question
  70. Suspension.. 1/4
  71. Suspension Q's... How Is Yours Setup
  72. Looking For Opinions On Motegi Rims
  73. Coilovers?
  74. Dtn's Painted Calipers
  75. Quick Brake Drum Question.
  76. Kyb Agx
  77. Upgrading Xg Brake System
  78. Who's Got Pics - Silver Tib W/black Wheels
  79. Tire Cleaner?
  80. New rims- woo hoo!
  81. New Wheels Are Coming
  82. RD1 Rotors and calipers on LC2
  83. Clicking Sound?
  84. Some Wheels For References
  85. Ordered My New Wheels, Opinions?
  86. No Brake Fluid Through The Rear Passengerside Brake Lines
  87. Suspension And Alignment Quote
  88. Rear Wheel Bearing Clarification
  89. Suspension Problem (clunk Noise)
  90. Rd1 Rear Disc Brakes
  91. Sounds Crazy, But Need To Raise The Front Up
  92. Big Brake Kit?
  93. Satabilizer Bushings
  94. Front End Suspension Overhaul
  95. New Wheels
  96. I'd Like To Take A Moment To Say... Dayum!
  97. Noise When Reversing
  98. How To Replace Cv Joint Boot
  99. Feeler For Rear Strut Bars
  100. Removing Inner Tie Rods
  101. Carbon Fiber Strut Bars?
  102. Valve Stems? Tpms?
  103. Need Suggestions On New Tires
  104. Beginnings Of The Diy Wilwood Kit
  105. Coilovers
  106. Which Tire Size?
  107. Rotor Maintenance
  108. Brakes Suggestions?
  109. I Want New Rims
  110. Brake Setup
  111. Eating Up Wheel Bearings
  112. Interactive Wheel/tire Size Calculator
  113. Newbie Rim Help
  114. Slotted versus Drilled Rotors
  115. Brake Pad Sticking?
  116. Alignment Data Help
  117. Help Me Find Rims
  118. Whheel or rim question
  119. Drums To Discs Swap
  120. New Rims... Looking For Lugs
  121. ARK Racing
  122. Brake Pads And Calipers, Where To Buy From.
  123. D2 Coilovers - Fully Adustable.
  124. Thinking about making one....
  125. New Tires
  126. Will The Rd2 Spindle Fit On The Rd1?
  127. I Need Cv And Tie Rod
  128. Springs and struts
  129. Springs for 2005 Tibruon
  130. Need Your Advice On Brake Pads
  131. Thoughts On Crossdrilled/slotted Rotors Vs Plain
  132. I Will Get Some Wheelies Too
  133. New 'shoes' For My 'whip' Yo
  134. Air Ride Suspension
  135. Removing Lower Control Arm
  136. New Springs Installed! *more Pix*
  137. Race/track Pads For Xg350 Calipers
  138. Noise That I Cannot Figure Out
  139. H&R Sport
  140. Brake Pad Question
  141. Quick Question
  142. Cabin Noises
  143. Suspension Headaches...
  144. Wheel/alignment Problem
  145. Interchangeable Springs Rd Gk
  146. Wider Tires...
  147. Tie Rod End Removal
  148. What's Wrong? Brake pad fitment issues
  149. New Rotors:)
  150. Wow Wheel Bearing Dead After 10,000 Miles.
  151. Coilover Sleeves
  152. Looking To Buy Rims... Any Suggestions?
  153. Passenger Wheel Pushed Back An Inch Or 2 :(
  154. Need Help With Tire Sizes Asap
  155. Will Eibach Springs For A Xd Fit On My Rd2
  156. Goodridge Vs Technafit Ss Brake Lines
  157. J2 Elantra Springs In My Tib
  158. Suspension
  159. Please Help Having Some Problems
  160. Wierd Grinding Sound
  161. Airride
  162. Shox.com
  163. Tire Size
  164. Slide Pin Replacements
  165. Yaya Polyurethane Bushings Part Numbers?
  166. Replacing Spindle (knuckle)
  167. Brake Grind
  168. Tire Problem
  169. Trouble Stopping?
  170. Looking For Black Rims.
  171. 2002 Accent Rear Brakes
  172. Breaking Hard / 60+ Mph Speeds
  173. Got A Great Deal On Tires
  174. Drift / Spinout Problem
  175. E-brake Always Engaged
  176. Brakes:)
  177. Smokey Burnouts
  178. Looking For New Rims Will It Fit
  179. Cool Brakes! Korean Guys, Care To Translate?
  180. 4 Lug To 5 Lug Conversion Plate
  181. Is It Required To Re-pack The Rear Wheel Bearings?
  182. Wheel Hub Adapter?!?
  183. Positive Camber
  184. Poll: Rims?
  185. Diy Yaya Motormount Install
  186. Brake Freeplay Adjustment
  187. Ksport Gt Pro Damper System
  188. New Control Arm
  189. Lifetime Alignment And Balance
  190. Loose E-brake
  191. Rims, What Do You Like Best?
  192. Nex Coilovers
  193. Got Dropzone?
  194. Caliper Upgrade For Stock Size Rotors
  195. Adjustable Endlinks
  196. Best For Traction
  197. Wheel Thumping Noise
  198. Cv Shaft Questions
  199. Caliper Paint Discount
  200. Would These Rims Fit Rd1?
  201. Pro System For Under $250
  202. Vogtland Springs
  203. Possible Frozen Caliper?
  204. Ksport Gt Pro Dampers
  205. How To Change Brake Lines
  206. Front Brakes Question
  207. What Brake Pad Is This?
  208. Complete Brake Re-build/ Upgrade
  209. Buying New Tires
  210. Squeaking Wheels
  211. My Front Strut Bar
  212. New Brakes For Rear
  213. I Need Your Stock Springs Part 2
  214. Sma Coil Springs ?
  215. Wheels Question
  216. Impressions: Kyb Agx Struts, H&r Springs, H&r Sway Bar
  217. Rear Brake
  218. Problem: Too Much Front-end Roll
  219. Will It Damage My Drivability....
  220. Cv Joints Axle Question
  221. What Size Tire?
  222. Info On Rims
  223. Coilover Kits Complete
  224. Wheel Balance Machine Help.
  225. New Rotors .. 6 Of Them?!?
  226. Diy Strut Bar
  227. New Rotors And Pads
  228. H&r Product ?
  229. Calculate Tire Dimensions
  230. Front Bearing Removal Problem
  231. Brake Guides
  232. I Need One Of Your Stock Springs.
  233. Can I Use Abs Rear Wheel Hub On A Non-abs Car?
  234. New Drilled And Slotted Rotors
  235. Wheel Size
  236. Wheel Bearing
  237. Ball Joint Boots?
  238. Diff Years ...same Suspension?
  239. Rear Caliper Troubles
  240. Question About 1st Gen Rd1 Captive To Non Captive Swap
  241. H&r 15mm Spacers
  242. Hubcentric Rings
  243. Rear Drilled Rotors
  244. Ball Joint
  245. My Rims Back On
  246. Rims Don't Fit
  247. Wider Stance, And Evening Front And Rear Out.
  248. Slotted Rotors
  249. Clicking In Steering
  250. My Steering Symptoms
