Power Steering To Manual
Hey guys I decided on getting rid of my power steering and going manual. I was told to bleed the fluid and remove the lines and block the holes. Do I have to get rid of the pulley, Any opinion would be great. Thanx
It's always appropriate to remove anything not in use.. Switches, pullies, motors, whatever. There's no point in having useless or undesired parts on a car.
I took mine off, just took the belt off and rode around for about a year and it sucked. I had a few close calls driving, put the belt back on and damm I appreciate power steering. makes it a whole lot easier to get around traffic.
You should remove the pump as you lose like 15lbs when you remove the unit.
And life w/o power steering isnt hard at all with a light car like this, the only time you miss it is when you have to go from all the way one side to all the way the other side while completely stopped..
