well i have never had slotted and drilled rotors untill now... when i press the brakes it makes a funky noise... is this proper or is something goin on???
no noise on mine either. When you changed your rotors, I bet you changed your pads too. If so, I bet you your caliper glide pin is seized. Did you lube it?
