Log in
View Full Version : Braking, Wheels, Tires, Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12
  1. just received rotors, are they supposed to be rough to the touch?
  2. Toyo T1-S vs. other 205/45/ZR16s
  3. veilside rims
  4. CAMBER KITS - Anyone
  5. Know anything about:
  6. Whiteline/Selby Sway bars
  7. Heavy Stoping Power
  8. Floor Brace????
  9. Opinions on Avon tires
  10. New Tires :D
  11. 4 Link Class Is In Session......
  12. SR strut bar
  13. Wheels/Tires Revisited
  14. Stronger axles
  15. Gunmetal rims
  16. weapon R coilovers
  17. Polyurethane
  18. I Have A Question
  19. I finally got it....HDK's under strut brace
  20. wheels and alignment
  21. Opinions on this?
  22. help fast please!!!!!!!!
  23. strut tower brace
  24. Eibach shocks
  25. Tires
  26. 2 or 4 winter tires?
  27. Quaife?..HP > Traction >Twisted Axel?
  28. Uh....What the hell is with that noise?
  29. 2 questions
  30. Opinions On Rims........
  31. Tiburon Handeling / Performance
  32. question
  33. Second thought about rims
  34. Which is the Best combo?
  35. enkei
  36. Is coil-over same as damper?
  37. Level 10
  38. is this true?
  39. another will they fit question!
  40. konis
  41. wheel&tire question
  42. strut bars
  43. Rims
  44. PSI
  45. What do you guys think?
  46. AfterMarket Rims
  47. Eibach springs and struts??'s
  48. SUSPENSION SUCKS!!!
  49. Wierd Rumbling Noise
  50. chrome or racing wheels
  51. Painting Wheels
  52. drop springs
  53. springs
  54. Stupid question...brake pads
  55. I LOVE These Rims.......
  56. Adjustable Shocks
  57. Stupid question about lowering spring
  58. brake pads!!!!!
  59. Tightest shocks avail
  60. air bags?
  61. New Lightweight Wheels
  62. Air Dynamic Racing coilovers?
  63. Hey moderators!!!
  64. Tire Choice -- Personal preference welcome...
  65. Purchased: 16x7 ALT Litespeeds!!
  66. Tires?
  67. Finalizing my Wheel choice -- Opinions on Scorchers and fitting 17x7.5
  68. About tires and quality.
  69. HDK Coilovers
  70. Wheel repair
  71. will 14" fit my car???
  72. lowest drop-biggest wheel???
  73. What size should i get?
  74. Getting the right wheels -- And thoughts on Motegi Wheels
  75. suspension ?
  76. Wheel Weight
  77. tire web site
  78. Will 215s fit?
  79. Wheel Off set??? HELP
  80. swaybars
  81. Driftin on Apex springs and stock struts.
  82. For Wheel Pros
  83. Wheel spacers
  84. APEX springs are installed
  85. The tiburon Rally car
  86. Going up
  87. Stock suspension vs Eibach pro kit drop PICS!
  88. Got new pics of wheels and suspension
  89. Got a question
  90. question about fit
  91. REAL QUICK!!!!
  92. Best Wheel Website!?
  93. Not Sure......someone HELP
  94. Starting to get frustrated...
  95. Suspension noise found -- swaybar problem
  96. Stock Rim Weight......
  97. Wheel Web Site
  98. replacing rotors on 97 w/ 99 tib rotors
  99. Drum shoe/lining question
  100. suspension woes -- attn: 2000 Low &Show
  101. B+G springs--Whats the difference?
  102. WTF are these two screws for?
  103. SR strut bars
  104. 17X7.5
  105. repacking a wheel bearing
  106. drum to disc conversion
  107. offsets and sizes
  108. Brembo Cross Drilled Rotors
  109. Eibach Pro Damper...
  110. My alignment
  111. wheel size
  112. Eibach Ground Control coil overs
  113. Brake Pads
  114. Cross drilled rotors?
  115. New Tire Update (Impressed) !!LONG!!
  116. Puhn-tang
  117. HVE springs
  118. Check out the rack!!!
  119. Questions on lowering my tib???
  120. Tire Help Urgently Needed
  121. Tenzo R Poke 10's
  122. sway bars
  123. rear strut
  124. Tire_Rims question
  125. Sway bars for tiburons??
  126. Just got my 17"'s on and I had 6 scews removed?
  127. upgradeing axels to handle higher HP
  128. changing the back to disc brakes
  129. strut bars???
  130. adjustable suspension
  131. got pictures
  132. Shocks..
  133. h&r
  134. I wanna lower my tibby! need to find struts and shocks( springs are easy to find)
  135. Which rim should I choose?
  136. Rare Tire size
  137. Pieces of advice..
  138. changing brakes
  139. Finally got my 17's now what rubber?
  140. Intrax Springs
  141. About the big brake upgrade
  142. Konig Toxxins on my Tib.
  143. Is it true?
  144. To 2000 Lo and Show Tibby...!
  145. Sway Bar = Fish Tail
  146. Looking for Coilovers for my tibby
  147. Vibrating Steering Wheel
  148. brake bias
  149. Painting Rims???
  150. big brake upgrade
  151. TIre changes
  152. What can help this..
  153. Spring clamps ??
  154. STUPID QUESTION
  155. What do you all think of American Racing Wheels?
  156. Strut Bars maybe fix this problem?
  157. motegi mr 7's for my Tibby
  158. Need rim help
  159. Should i get these rims or no?
  160. 205/50 or 205/40 ...
  161. question about 17" rims/tires
  162. BLKTIB u out there ?????
  163. UNHAPPY WITH SUSPENSION......
  164. You might need to check your rear swaybar for this
  165. coilovers
  166. To 2000 Lo and Show Tibby...!
  167. What should I do ?
  168. 18" wheels on 01 tiburon???
  169. Tire/Rims Question
  170. Installing lowering Springs, help!
  171. Random question about under strut brace
  172. SUSPENSION 101
  173. where to get h&r lowering springs
  174. BEST PERFORMANCE SPRINGS
  175. Wheel offset? will +38 work?
  176. Eibach Springs vs other?
  177. Standard Tib Wheels?
  178. New Wheels / Tires
  179. Whiteline/Selbys Rear Adjustable Swaybar
  180. anyone know where i can get some affordable rims/wheels?
  181. Eibach PRO-SYSTEM-PLUS?
  182. rubbing problems
  183. Opinions Needed!
  184. Who would be interested in a under strut brace?
  185. Question for 2000 Lo and So Tibby
  186. Ceramic Brake Pads
  187. Strut Bars
  188. Lightest Rims Avaliable?
  189. Lo&Show
  190. 4 wheel disc brake conversion ???
  191. help quick
  192. Stock Rim Size?
  193. how much should i drop my tibby
  194. What about these?
  195. Brake Job
  196. Woo Hoo Strut Bars!
  197. Painting Brake Calipers
  198. need some rims for my 97 Tiburon
  199. Cutting Springs
  200. Eibach Lowering Kit
  201. New Wheels....Im confused???
  202. Help with Rims
  203. Correct Offset?????
  204. Tiburon Owners Please Read...I Need Help
  205. Selby Anti-Sway Bar installed
  206. lower a tibby with 18's?
  207. Help with springs
  208. What's the actual offset on Tiburons???
  209. this is for da professional suspension folks
  210. lug nut thread size
  211. Random
  212. 2000lo&show
  213. Rattle!? Random!?!?
  214. Hankook Tires...
  215. SWEET RIMS!!
  216. 4x100 and 4x114.3 bolt patterns.+38 offset
  217. *HELP* Looking For Specific Rims
  218. can u put 18's on a tibby?
  219. I NEED NEW ROTORS!
  220. noisy brakes
  221. Painting Rims
  222. Suspension squeak... HELP!!!
  223. What do you guys think of these?
  224. RANDOM...
  225. What do you guys think...
  226. Squeeky Wheel
  227. Non-Captive brake set up
  228. Ramdom HELP!!! Rim problems....
  229. Under Strut Bar
  230. wheel question for random
  231. I GOT MY RIMS
  232. thinking this goes here....
  233. Question for Shark Racing
  234. Lug Pattern for tiburons...... HELP!!!!!!
  235. Q's on rims
  236. The Screws on the rotor????
  237. What set of lowering springs?
  238. Lowering springs help!
  239. Kumho or Falken tires?????
  240. 17's for the tibby
  241. suspension warrenty
  242. Serious question about rear strut bar!!!
  243. Window Issues
  244. Badass 17" will they fit?
  245. Duralumin Strut Bars
  246. Painting Calipers
  247. another one for random and the guys at shark racing
  248. rims question for random or anyone else?
  249. Braking problem
  250. drilled rotors
