changing the back to disc brakes
It should not be hard no. just locate the rear hub assembly from a junk yard for any year tiburon with rear discs. If you can, get them from a 1999 or newer, as those are the "non-captive" rotors.
You will need the complete hub assembly.
The Shark Racing Big Brake system comes with new front rotors, new calipers, and new pads. Front only. The front discs/rotors will not fit on the rear.
If you have a 1998 or older, you will need the parts to change from captive to non-captive.
Ok here I go again: I've look at my rear hubs from the inside rear on a couple of occasion with this mod in mind and I noticed there's a large nut (no jokes please) that is welded to the bolt that appears to hold it together. The next time someone get a chance to look at theirs can you check to see if yours is like this.
