help quick
Old Aug 3, 2001 | 05:45 AM
Mister694's Avatar
Default help quick
Where do i relocate my knock sensor when installing front strut bars?
****mutiple forum post
[ August 03, 2001: Message edited by: Mister694 ]
Old Aug 3, 2001 | 05:55 AM
Mister694's Avatar
n/m i used search
Old Aug 3, 2001 | 07:24 AM
You can relocate it anywhere, following these restrictions.
#1. The sensor must maintain it's current "north/south" orientation. If you reverse it 180 degrees, it will not work right.
#2. It must be mounted to the frame/body, not mounted to plastic, rubber, or to the engine.
Old Aug 3, 2001 | 09:56 AM
Guilty's Avatar
Vehicle: Custom Wagon
I left mine it the exact same place after I installed my strut tower brace.
Old Aug 3, 2001 | 11:42 AM
Mister694's Avatar
hey guilty i did the same :-p i used a metal file to file down the bracket so it would still fit :-)
Old Aug 3, 2001 | 12:26 PM
Guilty's Avatar
I had to do it that because I still had the orignal air box in there. And there was no room to put anywhere else but there. But as long as it works I'm going to keep it there.
