Log in
View Full Version : Braking, Wheels, Tires, Suspension
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12
  1. Have you ever had to fix a flat tire on the road?
  2. Help! - Lug Studs Too Short
  3. Pillow Ball Upper Strut Mounts
  4. Rotors for Ceramic Pads (Hawk), SS lines, and fluid
  5. Excited for my new rims
  6. Adding Abs?
  7. Strut Mounts Gone Bad..?
  8. Please Help Me With Rear Brakes
  9. One of my wheels are chipping
  10. I have a confession....
  11. R-compound tires...
  12. Hub Pin
  13. Good suspension reference/advice for Auto-x?
  14. Pushing pistons back for new pads
  15. E-brake adjustment
  16. 215/45/17
  17. GK suspension in an Elantra
  18. Ksport coilovers any good?
  19. Why Do My Brakes Have To Be A Pain?
  20. Popping During Turning/braking
  21. I don't understand lug nuts...
  22. Wheel painting
  23. B&g Springs?
  24. Need help with brakes
  25. Air struts for Accents
  26. The real truth about understeer
  27. Rim wax
  28. Upgrading My Rims And Tires
  29. Question about coil overs
  30. Alignment print-out
  31. Current Suspension Options
  32. new pads / soft pedal
  33. Stretched tires/hellaflush stuff
  34. What drop springs is everyone using?
  35. Is "European tuned suspension" a marketing gimmick?
  36. New lowering springs+struts = constant clicking? Help..
  37. Affects of plus-size wheels
  38. Are there any chrome rims that actually look good?
  39. Show me pics of white and bronze rims
  40. Tire noise
  41. Stripped Lug Nut...
  42. Rear strut bar
  43. Explain this to me
  44. Biggest selling rims in America?
  45. How Do You Protect Your Expensive Lugs When Torqueing Them
  46. Pentosin Racing brake fluid?
  47. Accord Rims On '97 Tib
  48. Will 215/40/17 fit on 7.5" rims?
  49. At what point are you creating wear?
  50. Accent brake swaps
  51. caliper paint
  52. Those of you who have painted your wheels...
  53. Brakes Loosing Pressure...
  54. ATE rotors?
  55. Going for the BBK
  56. give me your opinions of these
  57. Ball Joints Fitment
  58. Cryo treated rotors?
  59. Buying Used Shocks And Springs
  60. Hand Brake Adjustments
  61. Vogtland springs
  62. Can I Drive A Short Distance On Only 3 Lugnuts
  63. 18's and eibachs
  64. Rotiform - Custom Powdercoating
  65. Lug Nut Stuck On
  66. Good Summer Tire
  67. Accent racing suspension
  68. Nitto Neogens
  69. help painting calipers and drums
  70. bigwheels.net
  71. need help finding longer lugs
  72. Ark Strut Bars
  73. 215/40r17
  74. Sh$@@#y Ride
  75. ARK D-TP & S-TP Coilovers
  76. tire shine
  77. Accent brake pedal feel
  78. Floor bars in an accent
  79. Sumitomo Tires
  80. What rims are these?
  81. Staggered wheel fitment on an Elantra
  82. tires tires tires...
  83. anyone heard of a company called ichiba?
  84. EBC Green or Yellow?
  85. Cv Boot Replacement
  86. What is your All-Time Best FAVORITE Wheels/Rims ?
  87. trim rings
  88. Who do you recommend for brake lines?
  89. My rear brakes squeals and are wearing out., my fronts are fine and have alot of life.
  90. yay new lugs are here
  91. Wheel shake under HARD braking.
  92. Tenzo Wheel Quality?
  93. BBK for Accents?
  94. how much power do the stock axels handle?
  95. Everything You Need to Know about Wheels
  96. Which way do I rotate the tires? Front to back? Side to side?
  97. best struts for the money?
  98. What do you think of these rims?
  99. Nex Coilovers
  100. Control arm bushings
  101. Glow in the dark rims
  102. hubcentric rings
  103. sway bar advice
  104. Whiteline sway bars
  105. Possible Cm Lowering Spring Group Buy?
  106. Front-left Shuddering/shaking
  107. Race Tires?
  108. Stripes for your rims...the easy way...
  109. 2001 tiburon rear break (caliper giude rod stuck)
  110. Sprint Or Cm Lowering Springs?
  111. Searching for a certain type of strut bar
  112. Rebuilding Brake Calipers To Save $$
  113. rim size for 95 excel?. need new rubber so now the time...
  114. Suspension questions
  115. Finally Doing A Non Captive Swap
  116. I got some rims, check them out
  117. Caliper Help
  118. Coilover Fun :)
  119. tires and snow
  120. post pics of your wheels
  121. Questions About Coil Springs
  122. Modify Old Rear Strut Tower Brace
  123. Federal 595 SS
  124. Need Help
  125. Longer lugs?
  126. anyone ever heard of "improve" suspension company
  127. Meisterr Zeta Coilovers
  128. ball joints and tie rods
  129. raising rear end
  130. Winter Tires
  131. Need Help! Strange Steering Issue...
  132. Need A Picture Of A Completely Disassembled Rotor/hub
  133. mystery knocking noise
  134. Front strut bar
  135. Wanting lowering springs
  136. Am i Crazy or..
  137. 4 Lug To 5 Lug "conversion"
  138. Gk To Rd Hub Conversion
  139. Strut Brace
  140. Brake lines
  141. So i Picked up awesome rims.... FAIL!
  142. Suspension Modification For Drag Racing
  143. Lowering question
  144. Cutting springs
  145. Drilled Rotors
  146. How low
  147. Gk Vs. Rd Suspension
  148. Swaybar Info
  149. somebody stop me i'm thinking of buying coilover sleeves.
  150. Do I Need To Buy Upgraded Brake Pads?
  151. I Cant Have Anything Go Right!
  152. Rear disc options for x3?
  153. New breaks
  154. Car Rolls When Turning Right!
  155. Brake Rotor Trouble?
  156. Changing Rotors When...
  157. Tire fitment advice!
  158. Adr Rims On Our 99
  159. What do you guys think about this combo?
  160. Ball joints
  161. H&r Cup Kit (h And R Cup Kit)
  162. Got A Ground Control Coilover Conversion Kit Today
  163. Name These Wheels
  164. New tires
  165. Elantra/Tib Cilovers?
  166. Camber bolt question
  167. Inside A Ball Joint
  168. Aftermarket springs cause torque steer?
  169. You Think Tein Ss Coilovers With Edfc Are Possible With The Full 5 Lug Swap?
  170. Kyb Gr-2's Making Weird Noise
  171. How To Add Abs?
  172. Yaya Polyurethane Bushing Kit Fitment Problems
  173. springs vs. coilovers
  174. Snapped Bolt On Front Lower Control Arm
  175. Rubbing Tires
  176. Rear Squeak When Bouncing The Car
  177. New Tires. Yay!
  178. Where Can I Buy This Bolt?
  179. Changed Brakes, Now Problems
  180. Fitting Brakes From Another Car. How?
  181. How To Roll A Rubbing Fender
  182. When Changing Brake Lines And Bleeding Brakes
  183. E-brake Snapped
  184. Wondering if these will fit?
  185. Are these available?
  186. Tire Leak
  187. Quick Brake Question
  188. Hub Removal Help...
  189. Brake Upgrade From A Gk To Fit My Car
  190. Help With Rear Suspension
  191. Ebc 3gd Discs + Ebc Greenstuff Pads + Goodridge Ss Brake Lines
  192. Axel Problems
  193. Rattling Noise From Rear Tire
  194. New Shoes
  195. Broken Caliper Bracket = Xg350 Bbk
  196. Finally Got Me Some Wheels!
  197. Going 10/11/12's in a FWD?
  198. Rims
  199. Caster Alignment Kit..... Diy?
  200. Opinions on tires
  201. New Breaking System!
  202. Fixing My Rims ^_^
  203. Cross-member Cradle Mitsu Swap
  204. Rim Selection
  205. I Need An Opinion
  206. Brake Fluid?
  207. Alloy For Yellow Tib?
  208. Axle 101
  209. Camber Help!
  210. Need Important Info Regarding Our Knuckle.
  211. Car Is Making A New Noise
  212. 18" Wheels On Stock Suspension.
  213. 60+ Mph= Wheel Shake Under= Smooth
  214. Where The Hell Are The Prices?
  215. Strut And Spring Setup
  216. Non Captive Rotor Question
  217. Cleaning Or Possibly Restoring Alloy Wheels
  218. Tires 17" On Rd1 ?
  219. Front Wheels Rubbing Fenders
  220. Apex Lowering Springs
  221. My Tib's New Shoes!
  222. 4x114.3 - 4x100
  223. How Much Sag In Lowering Springs.
  224. I Started A Thread An Ddidnt See Where The Reply Button Was
  225. Suspension Question Fromt The Noob
  226. Bought new rims & tires.....
  227. Will These Style Spacers Work?
  228. Offset And Rim Width For Stock Wheels
  229. Looking for aftermarket sway bar for 01 Accent.
  230. Mushy Brakes
  231. In The Market For New Tires...
  232. Pics Of Some Rims
  233. Abs Light And E-brake Lights On
  234. Choosing The Right Rims
  235. My Tire Fell Off (almost)
  236. 5 lugs tiburon suspension on an LC?
  237. Brake Lights Stuck
  238. Captive Rotors And Wheel Spacers?
  239. Rear Control Arm
  240. 235/40/17 tires on Tibo 01 will those fit?
  241. It's A Brake Problem Now :/
  242. Anyone Installed Lowering Springs?
  243. Need Help With Changing All Rotors And Pads
  244. Misfortune With A Pothole
  245. Back End Of Car Stepping Out...
  246. Need Opinions
  247. E-brake Stuck
  248. Car Problem! Steering Wheel Shakes And Pulls Hard
  249. wheel rub
  250. Wheel Shaking While Accelerating?
