Adr Rims On Our 99
Old Sep 12, 2009 | 10:26 PM
ebrown9's Avatar
We just bought a set of ADR Intense wheels for my daughter's 99 tibby. Her boyfriend is having trouble getting them to set right because of those bolts on the rotors. I've been searching and have found so many opinions...spacers? remove the bolts? machine out a whole for the bolt? HELP. what should we do??
Old Sep 12, 2009 | 10:29 PM
Bommello's Avatar
What lug pattern are they?
Old Sep 12, 2009 | 10:30 PM
dddude55's Avatar
Vehicle: 2011 Kawasaki ZX6R
rd1's(97-99) have captive rotors in the front. This means the rotors are held to the hub by those 4 bolts on the rotor. If you take those out to fit the rim the wheel will fall off the car while driving. The only way other than swapping to a non-captive knuckle is to get spacers.
I don't remember where to find those but I would try a wheel store. Mine came with the rims since I bought them off another tib owner.
Edit --> If it is a universal bolt pattern. Most likely when you line the rim up to fit the studs properly, the other 4 holes will set over those rotor bolts perfectly. If you dont mind doing so you can dremel those holes slightly larger to fit over the bolts. It only hurts resale options.
Old Sep 13, 2009 | 02:07 AM
tihs is in the wrong section.. BUTTT..
adr intense are universal and would fit with captive.. if they were..
also.. are they 4 bolts, or two small screws? do you have a pic?
Old Sep 13, 2009 | 02:50 AM
ebrown9's Avatar
they are 4 bolt but there are two small screws. tirerack.com says not to remove the screws.
Old Sep 13, 2009 | 11:56 AM
99s dont have captive rotors anyway. Only the 97 and earlier 98s.
Take the screws out. It wont make a difference as the wheel holds the rotor on. No big deal. They likely will be hard to get out though depending on when the brakes were done. An impact screwdriver works best.
Old Sep 13, 2009 | 12:09 PM
yeah, didnt think the 99 had captive.. only 97..
those screws are just used when assembling the cars, so the rotor doesn't fall off on the assembly line.. most cars don't have the two small screws.. just take em out.
Old Sep 13, 2009 | 01:07 PM
tibbytib's Avatar
I have a 99 and agree. The two screws are used at the factory for assembly purposes only. Remove the philips screws and enjoy the wheels. smile.gif
Old Sep 13, 2009 | 03:23 PM
Moved into correct forum.
Old Sep 13, 2009 | 09:17 PM
TibFreak's Avatar
Yup, do away with them, mine had them too when I got my custom wheels put on at Tire Discounters. They just took them out, never had any issues to date.
