Need Important Info Regarding Our Knuckle.
I'm at work until 7, and I can't open hma from here.
I need the spacing measurment for the 2 caliper mounting holes on our knuckle.
Measurement needs to be from center to center on each hole. You can either A. Measure the knuckle. Or B. Measure the brake mounting bracket.
Who gets me the info first, will be rewarded with a little gift. It's not much, except to a few people hint:....coughdtncough
Oh this is info for a bbk bolt on.
Hm sorry i got your question wrong, i fail, I measured the caliper-to-bracket guide bolts..
Luckily I also have some front brake shields which go between the bracket and knuckle, the distance is about 12.8-12.9 cm, picture coming up.
Hope this helps, wish I could give you a more precise measurement, but the holes in the plate are probably a little bigger than the bolts and probably don't center perfectly anyway
