You Think Tein Ss Coilovers With Edfc Are Possible With The Full 5 Lug Swap?
I understand that the front coilovers and even full knuckle setup from the GK is a straight swap for us. What I'm curious about is if I should toss the rear end setup on to complete the full 5 lug swap with all the changes in the rear and then take the car to Tein. They've wanted my car to play with for the last few years, but I think the only type of RD tuner that'd spend the 1200 bucks on the nice suspension with EDFC would be the same guy to spend the bucks on the full 5 Lug conversion.
Hopefully Red sees this, or somebody tells him about it. Basically if its possible to just swap out the RD stock struts front and rear along with the 5 Lug conversion, then the Teins would work flawlessly. If that's the case, I can take the car to Tein (not far from here) and have them make us a new part number, which would include everything from the GK setup, but with springs better suited for the weight of our RDs since the GK is a sh!t ton heavier.
Whatcha think?
Whatcha think?
