Popping During Turning/braking
Old May 24, 2010 | 02:28 PM
Caj Darkmoon's Avatar
I have a 'popping' sound happening somewhere in my front driver side wheel/suspension area. It's not a quiet sound, and seems to be getting worse. Occurs during hard braking, hard acceleration, any time I turn the wheel hard (speed irrelevant, happens in parking lots) to either direction, and during urination.
Thoughts on a likely culprit?
Old May 24, 2010 | 02:45 PM
supercow's Avatar
sounds like ball joints or a-arm bushing
Old May 24, 2010 | 05:48 PM
or an axle, or a wheel bearing.
Old Jun 7, 2010 | 05:42 PM
Actual culprit = broken + loose tie rod end. Could move it a half inch up and down on it's hub/knuckle mounting point. Angle ground the s*** out of it and got it off and replaced.
