ARK D-TP & S-TP Coilovers
Old Mar 11, 2010 | 05:50 PM
Morningstar's Avatar
Vehicle: 2007 hyundai tiburon
Default ARK D-TP & S-TP Coilovers
just saw this on newtib if anyone is looking at buying they should jump on this.
http://www.newtiburon.com/forums/sho...d.php?t=180562
03-ON HYUNDAI TIBURON
ARK ST-P + Coilover System
ARK Performance brings ground-breaking finest quality damper kits that give defined comfort and balanced corner handling. To sophisticate our drivers without loosing their performance results, ARK damper kits offer diverse series adaptable to specific driving conditions. ST-P + Series, designed to adapt to all of your driving conditions, will create the harmony between power and stability which you demand. The full length adjustment system gives you the freewill to place various set-ups to meet your needs for specific road conditions. Hard rubber upper and lower mount designs in ST-P + series absorb noises as well as vibrations to allow the cabin for quiet operation while still offering flawless suspension proofing.
Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 16 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
Height adjustable
Front Spring Rate: 12kg/mm
Rear Spring Rate : 10kg/mm
- All bolt on system.
- 16-Level Adjustment
- Street - Soft Performance Spec.
- Rubber Mount
- Mono-tube Shock design for quick reacting and quite dampening operations.
- Adjustable Ride height
- All 15months manufacture limited Warranty
- Included helper spring.
MSRP $ 1799.00
STP PLUS : $829.00 + 59S/H
to anywhere in the lower 48 states / shipping anywhere in the lower 48 states / Canadian add $ 70.00 extra included Duty fee.
MSRP $ 1799.00
Hyundai Tiburon
ARK DT-P Coilover System
Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 16 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The ARK system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride. The ARK DT-P Coilover system has been designed with professional road racing in mind offering extremely high value and performance.
- Street & Track Performance Spec.
- Pillow Ball Mount / Camber adjustment
- Specially designed with JDM Racing Team
Spring Rates : 12kg/mm / 10kg/mm
MSRP $ 1899.00 + S/H
DTP :$929.00 + 59S/H
Old Mar 11, 2010 | 08:38 PM
Old Mar 11, 2010 | 10:26 PM
QUOTE (187sks @ Mar 11 2010, 08:38 PM)
shiiiit my b-day is on wednesday lol too bad im already getting a hana bumper and seibon TS hood =( lol
