Log in
View Full Version : Braking, Wheels, Tires, Suspension
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12
  1. Think Imma paint my rims this color
  2. accent rear disc swap?
  3. How many lug bolts have you snapped in your life?
  4. best rims for the track?
  5. heavy rims
  6. Machined rims
  7. Ok someone explain
  8. Cheaper alternative to Nitto 555's
  9. GT Style Tires
  10. C-clamp or piston tool
  11. Lug nut torque
  12. Difference in tire types
  13. 2004 Sonata - Brake Upgrade 10.1 To 11 Inch Possible?
  14. Bearings shot but is the
  15. lc accent upper strut mounts
  16. Chrome Gold Rims
  17. Kosei Wheel Fitment issues
  18. Wheels for my tib
  19. Why do people hate on stretched tires?
  20. arp wheel studs for rear?
  21. Tires & Wheels
  22. Recommendations on wheels?
  23. Random question
  24. FINALLY got my Tein springs put in
  25. BBK 05 Sonata 11' rotors
  26. KYB ADJUSTABLE SHOCKS
  27. 17x8 or 17x9
  28. Sine my thread was locked
  29. 99tib. suspension swap
  30. Anybody running 4 piston or 6 piston calipers?
  31. Ground Control Coil Over Kit
  32. Has anyone experienced complete brake failure at speed?
  33. Anyone have sprint springs
  34. Do I have a yay or nay?
  35. Painting brake calipers
  36. Any rims that are lightweight and have a brushed aluminum look?
  37. Suspension tuning
  38. Overfilling brake reservior
  39. Heel toe tire wear?
  40. Black Lug Nuts
  41. Megan Racing Coilovers
  42. got some new boots for the tib
  43. Question for you guys who buy used pads at junkyards
  44. Camber kits for H&R springs
  45. Are run flat tires really worth the extra money?
  46. What offset does this rim have?
  47. Caliper stickers
  48. Brake dust....
  49. Chrome polish for rim lip
  50. ball joint question
  51. What are the advantages of 2-piece or 3-piece wheels?
  52. Suspension ? for the pros
  53. Cordless impact wrenches
  54. Cleaning the sticky tape from weights off rims
  55. What do the members of HA think about these rims?
  56. Review: Elantra Touring Sway bar on a Sedan
  57. 16" rims fit over XG brakes?
  58. TPMS Systems
  59. Wheels
  60. This might be a dumb question
  61. Bent both my front rims this weekend
  62. Blank granduer discs
  63. Which rotors are better for hard use on street, Drilled or Slotted!
  64. Equus Wheel Specs
  65. How important are hubcentric rings?
  66. Whats the size of our wheel studs
  67. Stronger e-brake
  68. help with ksport coilovers install
  69. Finding good brake rotors?
  70. Can you mount a 225 tire on 16x7 wheel
  71. Lowering a tib but keeping stock like ride quality
  72. Rear Shocks vs. Rear Sway Bar
  73. Moog ball joints
  74. Are Rota Grids good rims?
  75. Camber, how much is too much?
  76. Rear disc swap and alignment
  77. having good brakes make you stop fast?
  78. Curbed my rear passenger side rim
  79. What do unpainted rims look like?
  80. Can I use 00 shocks nd struts with springs on my 99 accent??
  81. Oh hell yea!!!
  82. Brake Fluid vs. Clutch Fluid
  83. Question about bushings, please help!
  84. what kind of brake pads does everyone have?
  85. What size spacers?
  86. Are koni yellows worth the money?
  87. accent struts
  88. 19's on a tib?
  89. What offset for 17x9 rims
  90. If RDs and GKs have different bolt patterns
  91. Question about stabalizer bars
  92. Eibach Pro-Line lowering springs discontinued?
  93. accent brake swap problems
  94. Plastidipping rims
  95. How long did your stock struts last with lowering springs?
  96. Knockoff versus Name Brand
  97. Do springs really sag?
  98. To Swap or Not to Swap?
  99. Post pics of your painted STOCK rims
  100. coilover squeaking
  101. LC/LC2 Accent Brake Swap Walkthrough
  102. has anyone converted their tib to RWD or AWD?
  103. The time has come
  104. Bought new rims
  105. rd suspension questions
  106. Changing tires and painting rims
  107. Painted my front calipers
  108. Do i have brake drag?
  109. Hole in brake reservior
  110. Any tips for storing winter tires?
  111. Bushing Tools
  112. Other cars with rims that fit ours
  113. Pot hole season
  114. your opinion on wheel spacers
  115. Good drag radials
  116. Brake cylinder (drum) info - Need help!
  117. Tire Chains
  118. Abs delete
  119. How many wheel bearings have you had to replace?
  120. Rebuilding seized calipers
  121. I actually kind of like this (zips up flame suit)
  122. Lightweight rims
  123. Falken Azenis, Dunlop Star Specs, or Bridgestone RE-11s...
  124. What color rims for a red car?
  125. Black Chrome Wheels
  126. Will a rear "camber adjust" change the toe any?
  127. Tokico struts
  128. Stupid question about rear tire PSI
  129. Koni/Eibach Feeler Thread
  130. Eibach Sway Bar
  131. Got an early Christmas present from the wifey today
  132. Question about the stock donut tire
  133. Ever had a bent rim fixed?
  134. Suspension
  135. chemical strip?
  136. Opinions on the OG Mesh designed rims
  137. If you're thinking about buying studded tires for winter - read this!
  138. Snow tires are on...no more spirited driving
  139. Are pillowball mounts worth the money to buy?
  140. Brake dust on the inside of rims
  141. Painting Tire Letters
  142. Anti-seize on lugs
  143. Driving with mismatched tires on
  144. Low rolling resistance tires
  145. Question about wheel spacers
  146. Questions about Energy Suspension coil spring Isolators
  147. Overinflating winter tires: Better or worse in snow and ice?
  148. Double wishbone suspension
  149. How important is it to have bigger brakes with a turbo?
  150. Irregular tire wear
  151. Nitto 555's
  152. Which do you prefer
  153. Camber question
  154. How good does powder coating hold up in the snow?
  155. Howling Tires?
  156. Squeek from front wheel
  157. What do you guys think of these rims?
  158. Preventing rust on the rotors over winter storage
  159. Whats the easiest way to paint a rim outline?
  160. Cheap rims
  161. Searching for a certain tire calculator or formula
  162. Whats the lowest drop spring you can get for a tib?
  163. Rotors and SS lines
  164. Good all seasons or cheap winter tires for winter months?
  165. What causes bulges in tire sidewalls
  166. Is there any way ti adjust the height of the brake pedal?
  167. Will 4 pound lighter rims make any acceleration difference?
  168. Anyone ever used this paint on their rim lips?
  169. Black rims - still cool or played out?
  170. All black or all gold rotors
  171. Whats the widest tires you can put on a tib at stock height?
  172. Brakes super soft after timing belt and water pump?
  173. testing master cylinder
  174. Koni yellows is leaking oil
  175. Question about rusty brake rotors
  176. Safe cleaner for spray painted wheels
  177. Stripping chrome off rims
  178. Snow tire shopping ughh
  179. Suspension does't feel right
  180. True bolt on LC2 Accent Brake swap???
  181. How many times have you changed your rims?
  182. Time for new tires
  183. Eibach pro kit or sportline springs?
  184. Winter tire size
  185. Ken Block style rims
  186. Gold/Bronze rims for white car?
  187. Looking for a TE37 knockoff
  188. Seized Rear Caliper, Should I buy just one, or 2??
  189. Winter tire shopping, yup its that time of the year again
  190. Is there a special logic to caliper placement
  191. Coilovers too compressed?
  192. powdercoating/painting stock rims
  193. How do you improve vehicles with understeer?
  194. Looking for a Mesh wheel design
  195. Brake cooling ducts
  196. New wheel color
  197. Having a bodykit is not fun for alignments
  198. DOT 4 or DOT 5 fluid?
  199. Whats the best lug tightening sequence?
  200. Sways: does size matter?
  201. XXR 962
  202. Good lord these rims are so hot!
  203. high heat Hyundai sticker for calipers
  204. Untraditional rim colors
  205. How soon does car need alignment after suspension install?
  206. Avoid plastic bags on the highway
  207. S/S brake line change question
  208. Coilover Install Help
  209. Heat cycling tires
  210. CV Boot has a hole in it
  211. What happens if you have uni-directional tires going the wrong way?
  212. Question about wheel bearings
  213. yokohama parada spec-x
  214. What tire are you running?
  215. Koni Yellow versus Koni Red
  216. do you prefer rims with or without center caps?
  217. Do you buy knock off rims?
  218. Interesting tires
  219. elantra or tiburon steel braided brake lines
  220. I want these rims!
  221. Anybody runniny 17x8's?
  222. xd elantra suspension on an lc2 accent w/ brake swap
  223. pad between the coil springs
  224. need help asap tire size ?
  225. Spray on spray off rim cleaner
  226. Resurfacing Brake Rotors -- Why NOT to do it!
  227. What kind of security lug nuts to get?
  228. What's more important: Curb Weight or Weight Ratio?
  229. Coil overs with Koni yellows
  230. How hard is it lowering your own car?
  231. Help with spacers
  232. Got some new rims coming
  233. 17's or 18's on my tib
  234. White on White
  235. will 15 inch rims fit over brake swap
  236. Eibach camber kits
  237. new wheel studs
  238. Looking for brake upgrade advice
  239. Sway bar / strut bar question ...
  240. Has anyone used TyreGuardian?
  241. how do people get curb rash??
  242. Brake Fluid Shelf Life?
  243. Cv / Axle Replacement Questions
  244. Removing rear rotors
  245. How long did your stock shocks last after dropping your ride
  246. Tire rotation question
  247. Grinding Sound When I Turn
  248. 2 inch drop with 17" rims
  249. Gold or red calipers?
  250. Alignment Question
