2 inch drop with 17" rims
Old Jun 24, 2010 | 03:07 PM
Hbc's Avatar
Hbc
Vehicle: 2011 Hyundai Genesis 2.0T
Default 2 inch drop with 17" rims
Hi Everyone,
I have a 2002 Accent GSI, and have 17in rims with 205/45/17.
I'm about to drop it 2inches with Intrax springs. I believe its 2inch in the front and 1.8 for the rear.
I was told i may need a camber kit, and alignment after that, and roll the fenders.
Does anyone have a similar setup?? Any problems ??
Thanks for any advice.
H
Old Jun 24, 2010 | 04:16 PM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
I have/ had the same set up and camber bolts are needed. My tires were 205/40 and the fenders didnt need rolled but there was some rubbing in the rear and not in a spot that can be rolled. With 205/45 u may end up needing to roll your fenders.
Old Jun 25, 2010 | 11:36 AM
Hbc's Avatar
Hbc
QUOTE (HotBlue02 @ Jun 24 2010, 06:16 PM)
Ok, thanks
Picking the intrax springs up tomorrow, i'll see how it rides when its installed.
Thanks again.
H
Old Jun 25, 2010 | 01:03 PM
The 205/45/17 size is gonna give you hell. That tire is too tall. Going to a 205/40/17 would help quite a bit.
Either way, you're likely to have rubbing. It'll be a matter of seeing where and making it work.
