Suspension ? for the pros
Old May 20, 2011 | 12:53 PM
RED HOT TIBURON's Avatar
Vehicle: 2000 Tiburon
Default Suspension ? for the pros
If you were to lower the front end slightly with a small drop spring, like Eibach, and left the back end in with the stock suspension (giving the car a small raked appearance), how much would the handling suck going around turns? Would you have to do something to the back end to compensate for the front end having better suspension in it?
Old May 20, 2011 | 01:28 PM
You wouldn't have to, but it would handle pretty weird.
Old May 20, 2011 | 05:53 PM
I'll go out on a limb and say most people wouldn't even notice a difference of an inch of geometry change, if the spring rates were close. A race driver, yes, of course. A commuter, not so much.
Old May 21, 2011 | 01:24 PM
BetaRD2's Avatar
Vehicle: Tiburon 2001
i havent tried on my tiburon but i used to have an X3 accent which i took 2 coils out of the front and left the rears stock and it drove nice but it was pretty sketchy going fast into turns the back en felt a bit light
Old May 21, 2011 | 04:50 PM
The back of an accent IS light.
Old May 22, 2011 | 10:02 AM
So you're going to drop the front end 1.2" and use stiffer springs, but leave the stock struts up front???? and leave the stock suspension in the rear?
Uh, yeah, you'll notice that it handles like crap. If you change the springs, change the dampners (strut/shock) @ the same time.
Also, consider bushings and front/rear swaybars while you are at it, or as your next modification after the springs/struts.
Old May 22, 2011 | 11:42 AM
wheel_of_steel's Avatar
i think it is impossible to answer this question correctly without a proper drawing of the suspensions at the front and rear, with the centres of gravity F + R etc etc. my guesstimate would be that the back will lose some grip relative to the front, and you'll need to re-align your tires and headlights.
Old May 22, 2011 | 02:13 PM
LOL Random it already handles poorly if the stock struts are still in place!
