xd elantra suspension on an lc2 accent w/ brake swap
Old Jul 23, 2010 | 08:33 PM
rdgmk23's Avatar
Vehicle: 2004 hyundai accent
Default xd elantra suspension on an lc2 accent w/ brake swap
if you do the brake swap with elantra spindles can you use the elantra suspension on an accent you would think it would fit.
Old Jul 23, 2010 | 09:11 PM
Define suspension...
If you converted the strut tops (different bolt pattern) the front strut/spring combo might work. The combo is a bit taller though so you would want a decent drop spring and a strut capable of lowering.
In the rear, I have contemplated attempting swapping in the strut/spring combo and rear knuckle w/ my strut top. I haven't compared enough to see if that's feasible without making custom control arms or not though. I doubt that you can use the XD control arms in the front or back, but if you're really interested get out a measuring tape and compare. I don't know if anyone has tried.
Old Jul 23, 2010 | 09:22 PM
rdgmk23's Avatar
what about the rd tiburon shocks and springs and what if you would use the accent top mount on the struts.
Old Jul 23, 2010 | 09:46 PM
I've never measured the RD's strut top bolt pattern, but they may match the Accent. I think I heard that they did. If I remember the next time I have a RD here I'll measure.
