Heel toe tire wear?
As the title indicates. I have a GK, and I'm experiencing heel toe wear on both inside and outside edges of both front tires. Alignment is good. All the ball joints look good and the tie rods were recently replaced. Struts are original, but seem to work good. And the car is on completely stock suspension. Anyone know?
^^^^^ He speaks the truth, under inflated tire simply just tire pressure, just as if you run to much you will run only the middle of the tires out...
You should probably run just like an extra 2 PSI in each tire to get the tire tread even!
