Coil overs with Koni yellows
Old Jul 15, 2010 | 09:21 AM
lilredaccent's Avatar
Vehicle: 2000 Red Accent 4 Door
Default Coil overs with Koni yellows
I have a really expensive set of Koni yellow adjustable struts which is probably the best struts you can buy, along with a cheap set of Weapon R Circuit coil overs. They're just the sleeve type and I know usually those types are bad and dont give a good ride quality or handling. However I was wondering if I added the Koni yellows to them, would it all balance everything out and still be great for handling and driving? If not, would it be better for me to get a set of static drop springs like Eibachs and add the Koni yellows to them?
Old Jul 15, 2010 | 04:05 PM
It sort of depends on your intended use of the car.
You will probably be able to dial in the fastest track times with a set of coilover sleeves and the yellows, but it'll be unrefined and somewhat sloppy. You can get 95% of the way there, with a consistent ride and consistent predictable handling without weird noises and shifting coming from the suspension if you get a set of decent lowering springs and run the yellows.
So, if I was driving it on the road very often, I would go with regular lowering springs. If it was primarily a race car I would consider coilover sleeves. A set of full coilovers is also acceptable for both worlds, but they'll be more at home on a track also, and can't utilise your Koni Yellows.
