Log in
View Full Version : Braking, Wheels, Tires, Suspension
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12
  1. New Caliper = Spongy Brakes?
  2. 17's Won't Fit!?!
  3. Rims For Captive Setup
  4. Rd2 Bbk
  5. Squeaking From Rear
  6. Stock 55 Series Vs 50 Series.
  7. My New Bbk From Willwood
  8. Betcha None Of U Guys Have This Many
  9. Springs From Ebay
  10. Question About Rim Sizes
  11. Got Some Wheels Today... Need Some Help
  12. Elantra Springs?
  13. Suspension Install
  14. Tire Marker
  15. Rims Rims Rims
  16. Bsa Rims
  17. Wheel Weight List
  18. Tein Looking For R&D Car
  19. Warning,... Fake Teins On The Market!
  20. Bented And Cracked Rims
  21. Suspension Bushings
  22. Wheel Alignment
  23. Front And Rear Strut Bars?
  24. Center Cap
  25. Another Wheel Bearing Post...
  26. Hydraulics
  27. Changing Rear Bushings (silent-blocks)
  28. Pimpstar
  29. Where To Get These Wheels? (korean Spec)
  30. Wheel Problem!
  31. People With A 2"+ Drop
  32. Just Changed My Bearings..now What?
  33. Ok Hangul Experts, Here Is One For You
  34. Elantra GT Suspension Quirks
  35. Brembo Oem Replacements For Cheap
  36. 8mm Spacers
  37. B&g Rs Line Coilovers
  38. What Color Wheel Looks The Best With A Black 01 Tib
  39. Any Pros To The 2001 Tiburon's Stock Rim?
  40. Accent 1995 Brakes (Hello from Costa Rica)
  41. Kumho Mx-c
  42. New Wheel Offset Question..
  43. Rotors, Rotors, Rotors?
  44. Ahh! Tore Up A Tire Today.
  45. It's Time To Choose Tires
  46. My New Rims, Neeed Help
  47. What Rims Can Fit The Intrax Springs?
  48. What Shocks With 2 Inch+ Drop?
  49. Places for good rim & tires deals....
  50. Xg350 Calipers And Sonata Rotors?
  51. Cut Cv Boot
  52. Wheel And Tire Related Dilemma
  53. Suspension Related Questions
  54. Anyone With Groundcontrols?
  55. Tibby Suspension Project
  56. Info On Ss Brake Lines
  57. Where Do You Guys Suggest To Get Wheels?....
  58. Traction Bar Kits - Eliminate Wheel Hop!
  59. What Lug Nuts Do You Use?
  60. New Shocks
  61. Hks Springs
  62. Extremely Loud Crunching And Cracking
  63. I Need New Rubber... Best Tire Out There Right Now?
  64. Wow!
  65. I Have Bad Luck...
  66. Lowering Springs For Rd1?
  67. Omg, Jon's Gonna Buy Some Rims!
  68. Rear Brake Upgrades?
  69. New Rotor Question
  70. Need Help
  71. Rear Strut Bar?
  72. Rattling Noise From Rear
  73. Suspension Questions?
  74. What's The Stud Pattern & Offset On A '99 Tiburon ?
  75. Will These Tire Sizes Rub?!?!
  76. Rear Disc Swap Pictures, 56k Killer
  77. Livin By The Ocean,snow,salt,rust,snap!
  78. 98 Front Calipers Will Fit 99 Non-captive Setup?
  79. Brake Job Help!
  80. Good Brake Pads?
  81. Drop Springs
  82. Which Tires Would You Use For Autox?
  83. Going To Change Shocks
  84. What Is The Difference Between Captive And Non-captive Rotor
  85. Brand New Big Brake Kit Available
  86. Which Colour Wheels?
  87. Whiteline Parts
  88. Yaya Suspension Bushing Kit
  89. Cheap Performance Tire
  90. Wheel Bearing
  91. Intrax Are On!
  92. Q About New Wheels
  93. Sway Bar Q
  94. I Need Someone In The Nj Area To Test Out A Strut Bar
  95. E Brake Problem
  96. Opinion On Rims Needed
  97. Polished Stock Wheels
  98. New Wheels!
  99. Humming Humming Just Keeps Humming.
  100. Camber Adjustment 01 Tib
  101. Rotors And Pads
  102. New Rims
  103. Sonota To Accent Brake Swap
  104. Spring Problems?
  105. Captive Rotor Question?
  106. Uhaul Ruins Tibs Rear Struts
  107. Question About Shocks/struts
  108. Black Tib With Gunmetal Wheels W/polished Lip
  109. Rear Stabilizer Problem
  110. Wheel Bearings
  111. Aternate Wheel/tire Combo
  112. New Wheels Help!
  113. Parts On The Way!
  114. Ok, I'm Starting To Get Frustrated
  115. Wilwood Calipers
  116. Front Frame Damage
  117. Cleaning Wheels And Tyres.
  118. Front Hubs
  119. Bad Steering Problem
  120. Lockdown!
  121. Rim Oppinions
  122. Photoshop Pls
  123. Someone Help Me Out With Webtech?
  124. Rim Leaking?
  125. Necessary To Put On Winter Tires?
  126. Streaching The Tyres... Good Or Bad !?
  127. 17" Wheels
  128. Some More Goodies
  129. Taking Off Captive Rotors
  130. What Tires Do You Use For Winter?
  131. Crazy Sound Coming From Rear Of Car.
  132. Captive To Non Captive Rotors
  133. Winter Tires Warning
  134. Coilovers...help!
  135. Strut/ Spring Combo Vs Na Coilovers
  136. Choosing Some New Rims/tires.
  137. Compress Rear Brakes... How?
  138. Rim Choices
  139. Discussion About Drilled Rotors
  140. Cyro Treated Rotors
  141. Clicky Brakes...
  142. Shims Necessary? Changing Rear Brakes
  143. Evo Fusion Strut Bar
  144. Camber Issues.
  145. Shock And Strut Prices
  146. Koni Or Kyb ?
  147. Replacement Center Caps
  148. Proportioning Valve
  149. Tire/ Suspension Help!
  150. Stock Offset?
  151. Spring Tech Lowering Springs
  152. Rim Question
  153. Excessive Dirtiness
  154. 16" Vs 17" Rims
  155. Tires
  156. Fixing A Leak
  157. New Tires Opinions Wanted
  158. Wheel Stud
  159. Rear Sway Bar Installed Today
  160. 15" Winter Rims
  161. Fedoro Brake Pads....
  162. Lug Nut Pattern?
  163. Real Big Brake Kit.. 13" 2-piece Rotors 4piston Calipers
  164. 360 Degree Spin Doing 110kmph
  165. Best Winter/as Sport Tire?
  166. Finally Machined Front Rotors
  167. Slid Into A Curb
  168. Hydraulics
  169. 18inch Wheel Fitment
  170. Hmmm... I Think Something Broke...
  171. Brake Pads
  172. Rotors
  173. Need Some Rim Chops.
  174. Drag Wheels
  175. Rotorpros Rotor Question
  176. Eibach Pro Street Or H&r Coilovers
  177. Tire Poll
  178. Airbags In Winter?
  179. People With Slammed Rides
  180. Xg Brakes
  181. Springs?
  182. Falken Ziex 512's
  183. Just Bought Eibach Pro-kit. Need Some Info
  184. Eibach Pro System Vs Pro System Plus
  185. Need Options
  186. Camber Adjustment Bolts?
  187. Guys I Need New Brakes.. Does This Seem Like ..
  188. For Those Who've Done The Captive Rotor Swap!
  189. Funny Noises
  190. Ebc Greenstuff + Thinner Spacers = More Shakey
  191. Rotor Rust
  192. New! Bose Linear Electromagnetic Suspension
  193. Brake Upgrade (x3 + Rd1)
  194. Captive Rotors Brake Swap Avoided!
  195. Vibration Problems..
  196. Kspec Coilovers
  197. Really Cheap Big Brake Setup
  198. 16 Inch Tires
  199. Shit! I Damaged My Tire
  200. Where To Buy Rota Rims?
  201. Sway Bar End Links?
  202. Rear Spindle Nut?
  203. Drum To Disc Brake Swap
  204. Brake Calipers
  205. Center Bar?
  206. Shark Racing Big Brake Kit
  207. Cost Of Oem Rims
  208. Rotors
  209. Air Bags
  210. Quick-q's Before Buying Rims.
  211. Tire Question
  212. Wheels!
  213. Cutting Stock Springs...
  214. Rear Ebc Greenstuff Brake Pads
  215. Opinion Needed
  216. Front Wheel Drive = Oversteer?
  217. Again Bearings
  218. Going To Be Buying Brake Upgrades Soon
  219. Rd1 Brake Swap
  220. Camber With Airbags
  221. 5-lug Conversion To A Rd2?
  222. Mildly Bent Rim
  223. Knocking Sound
  224. Wedssport
  225. Wheel Bearings = $300?
  226. Obx Front And Rear Camber Kit
  227. Mang..this Sucks! (wheel Rotor Fitment)
  228. Help Needed...
  229. H&r Race Springs
  230. Yet Another Odd Noise Question
  231. Panic...
  232. Brakes
  233. Eibach Pro Kit Plus Help?
  234. Steering Wheel Shaking
  235. How Can You Tell If A Brake Is Working
  236. Squeaking From Rear
  237. Eibach Sportline Springs
  238. Where To Find Lightweight Rims??
  239. Help Me Choose A Rear Strutbar
  240. Looking For New Rims And Found These
  241. Euro Tib Strutt Bar Installation.
  242. Tirewall Cracked!
  243. Damn Chiltons Manual... Need Help Now.
  244. I Don't Know My Rims
  245. Captive Brakes
  246. Tire Pressure
  247. T & P Shocks
  248. Rotors Question..
  249. Wheel Help...
  250. Good Idea Or Bad??
