Tire Question
Old Aug 29, 2005 | 02:28 PM
would this tire size cause problems?
222/50/15
i would use it for track only occasions and my car is lowered on eibachs
its only $4 more per tire and its way wider
i would have to get some new front rims obviously
would they fit on a 15x7 rim?
Old Aug 29, 2005 | 02:29 PM
KayJai's Avatar
222?
Old Aug 29, 2005 | 02:30 PM
OOPS
ment 225 sorry
Old Aug 29, 2005 | 02:57 PM
thats really pushing it. i think they would rub, but im not sure.
Old Aug 29, 2005 | 03:10 PM
OdessitPashka's Avatar
If it's only going to be for the track day then you should be just fine. I wouldn't recommend driving it every day though.
WHich tire are you getting?
Old Aug 29, 2005 | 03:15 PM
well it wont be until next season probably since im injured
but i was lookin at the bfg drag radials or the khumo victoracers
EDIT
also who makes a cheap lightweight 15X7 wheel?
Old Aug 29, 2005 | 03:47 PM
Look into BGF drag radials or even better MT drag radials. Do you have enough power not to bog down with all these sticky tires?
Check out jegs.com for light-weight wheels.
Old Aug 29, 2005 | 03:55 PM
Old Aug 29, 2005 | 03:58 PM
blah. Good luck with your S/C...
