Eibach Pro Kit Plus Help?
I finally did it.
I bought the Eibach Pro System Plus and just opened the boxes to see what I got. On the outside of the box are pictures of the components inside.
Upon examining the contents of the box I noticed that I may be missing some hardware. Stuff like the yellow bump stops and sway bar ends etc. It came with the proper bushings for the sway bars but I am curious why they would show things on the outside of the box that doesn't come with the kit.
Here is the pic on the outside of the box.
Here is a pic of what came in the kit.
http://www.hamishgt.ca/vixengt/cottonmouth/eibach2.JPG
I was also wondering if I need a camber kit. Has anyone who installed this kit come across this problem? Is it necesssary? Is there any other things that I should get before beginning the install?
hey graham, the picture outside is just a general pic of the product and not specifically for the tib. It looks like parts for a honda on the outside judging by the suspension setup.
From the pic you linked there, it looks like you got all that you need.
I personally have full race coilovers and my car is lowered more than that kit will lower your car and i have had no camber issues. I'm sure its not perfect 0 camber, but it might be veryyyy little, soo little that i wouldnt even bother with a camber kit, infact on my coilovers, i actually have it set for more negative camber at the front cause i wasnt getting as much as i wanted.
BTW how much did that kit set you back?
Vic
Vic
you will get some negative camber from lowering, but not enough that i think you will have too much. like - 1.5 front, and a little under a full degree of negative in the rear(like .8).
when you get it aligned after the springs settle, check those camber numbers. im at a whole shitload of negative camber on one corner, but i really cant see any crappy tire wear yet.
QUOTE (NightShark @ Aug 5 2005, 03:09 PM)
Vic
Vic
I spent $1400 tax in for the whole thing. Seemed like a pretty good price to me. What do you think?
*Use the edit button man - tibby01*
1400 is in canadian dollars, right?
little high. tirerack has it for 1022 before shipping, and we have found a couple places on here that offer the whole kit for like 200 cheaper.
EDIT- heres the topic where we found the good price:
http://www.rdtiburon.com/index.php?s...c=17&hl=eibach
double edit-
http://www.shox.com/appguide/shoxsho...ctsdisplay.php
and i think its even cheaper if you mention you belong to a forum.
double edit-
QUOTE (tibby01 @ Aug 5 2005, 10:14 PM)
double edit-
double edit-
That is $1400 Canadian!!! Taxes and shipping included. Not USD!!
