Eibach Pro System Vs Pro System Plus
Old Sep 21, 2005 | 04:01 PM
Screwdriver's Avatar
Tirerack Link
There's a $400 price difference on Tirerack and from what I can see, the only difference is the sway bar.
Won't it make better sense to just get the sway bar later at a cheaper price?
Old Sep 21, 2005 | 04:08 PM
00tibby's Avatar
depends, I cant find a place to get me the sway bars.......till dec. soooooo i would take that offer if you could.
Old Sep 21, 2005 | 10:25 PM
KayJai's Avatar
You save $20 getting the Pro system plus with the sway bars including, than if you were to go and get the Pro system AND THEN the sway bars separately,... I don't see what the problem is there,...
It's better to get it as a combo then to buy it separately,...
Old Sep 22, 2005 | 08:36 AM
I was curious if they sold both bars. You see, it says anti roll bar, not bars.
Old Sep 22, 2005 | 11:09 AM
gspots-01htse-'s Avatar
what are the actual prices because if you have to pay a bunch at one time
lots of ppl will feel bad about paying so much at one time.
so what are the prices?
Old Sep 22, 2005 | 11:12 AM
Zman's Avatar
No, they include both sway bars, front and rear.
If you have the money, go for it because springs make 50% of the improvement, and swaybars make the other 50% (OK if you want springs 40%, Sway bars 40% and shocks 20%).
Eibach shocks are expensive compared with KYB GR2, you could buy the ProKit spring set, and the Sway bar kit only, that should sum like $620 and then get the 4 KYB GR2 for ~$220, totalling ~$850 so it's up to you if you want to save the difference.
Old Sep 22, 2005 | 01:48 PM
KayJai's Avatar
QUOTE (gspots-01htse- @ Sep 22 2005, 12:09 PM)
Check the first link
Old Sep 28, 2005 | 07:37 AM
baelzbub's Avatar
Just an FYI:
I scored the KYB GR2's off eBay a little cheaper than what TireRack sells them for, from a Vendor called Sparkplugssource
It's around $40 cheaper depending on shipping, but (for me anyways) forty bux is forty bux. Just thought I'd pass on the info.
-Fran
