For Those Who've Done The Captive Rotor Swap!
Old Sep 16, 2005 | 08:34 PM
NightShark's Avatar
Is it really necessary to get calipers as well for the swap?
i dont see why we can't use the olds
Old Sep 16, 2005 | 08:35 PM
gotspeed13's Avatar
Vehicle: 1998 Hyundai Tiburon
No, although the part numbers for the brake pads are different between the two.
Old Sep 16, 2005 | 08:51 PM
absolutely not. i swapped the hub with no problem. got some brake pads, everything fits well. why are you doing a captive rotor swap when you already have rims?
Old Sep 17, 2005 | 06:26 AM
NightShark's Avatar
^^^ what parts did you get to do the swap? why did you get brake pads if you kept the rd1 calipers?
i had to modify the rims a bit to get the fronts to fit..
Old Sep 17, 2005 | 05:52 PM
No, you don't need to swap the calipers over. I have both front calipers from a '99 just sitting around... I kept the original ones on.
If you got 2nd hand non-captive rotors, it might be a good idea to get the disc surface machined.
I think it's also best to machine the discs/rotors when replacing pads (I did neither when doing the swap... So far so good).
Old Sep 17, 2005 | 10:11 PM
NightShark's Avatar
yeea i'm not even gonna bother getting the pads and rotors, i just need the spindle and hub cause i'm gonna get cross drilled rotors again to match the ones i got on my car already
Old Sep 20, 2005 | 06:54 AM
NightShark's Avatar
if i get the hub and spindle off a rd2, does that mean the wheel bearings come with it?
Old Sep 20, 2005 | 03:36 PM
Yes, unless they give it to you in individual pieces.
