Cutting Stock Springs...
Old Aug 29, 2005 | 11:52 AM
1stGenTib's Avatar
Vehicle: 1997 Hyundai Tiburon FX
Cut down the stock springs 1.5". yes or no?
Old Aug 29, 2005 | 11:56 AM
12SecRD's Avatar
I took a coil out of my springs a few yrs back. Lowered the car the exact same as when I put in the eibach springs. So it dropped me down about 1".
Old Aug 29, 2005 | 11:59 AM
Cutting spings will give you a rough ride.
Old Aug 29, 2005 | 12:02 PM
1stGenTib's Avatar
can i do it myself at home or will i need to take it to a shop?
Old Aug 29, 2005 | 12:04 PM
You shouldn't do it at all. It's been posted about.
It gives your car a ROUGH RIDE, as in BOUNCING ALL OVER THE GODDAMNED PLACE.
It's not safe to do either. Save up a bit of cash and pick up some Eibach or other springs on ebay.
Old Aug 29, 2005 | 12:18 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
bad idea!
all springs are designed for a car specific (weight of the car, clearance, suspension geometry, etc...) And by modyfying springs you make it unsafe to ride.
Best way - collect some money and buy springs that was designed for your car.
Old Aug 29, 2005 | 12:22 PM
Zman's Avatar
There are many reasons as to why you should NOT cut your springs.
Regards to the bird who told you to do it, tell him to search here or at the old forums at Hyundai Aftermarket to learn before he tells stories, because he is misleading fellow tuners.
Old Aug 29, 2005 | 12:26 PM
DO NOT CUT YOUR SPRINGS
it is EXTREMELY unsafe i knew someone that cut his and since the spring had no real complete coil to sit on the perch one day he hit a bump and the spring disconnected from the strut causing his car to completely fall on one side of the vehicle on the freeway! after spinning a few times cuz the body fell on the tire he ended up totalling his car
bent the frame, control arm, damaged the inner lining, ripped the hell out of the fender, broke the hub, ruined his 18"rim and his nitto tires and thats just what pictures showed...i still have the pics somewhere online i should look for them
all cuz he didnt want to pay 100 for some actual springs....
Old Aug 29, 2005 | 12:28 PM
1stGenTib's Avatar
this is why i ask b4 i do, now the eibach pros, they give about a 1.2 drop but wont it be stupid bouncey with stock struts? or will it be really stiff?... until i put kyb on...
Old Aug 29, 2005 | 12:31 PM
Viper's Avatar
If you cut off your springs, I'll cut off your nuts
I swear I will.....
