Brake Job Help!
Old Feb 10, 2006 | 04:06 PM
landshark16's Avatar
Im in the middle of a brake job on the back and the caliper wont sit right on the bracket. When I tighten it down, the rotor wont sit flush. Am I missing something? Will not having the little clips for the pads affect it? Or the parking brake cable? Anything?
Old Feb 10, 2006 | 04:13 PM
um the clips are required
is the ebrake engaged?
Old Feb 10, 2006 | 04:16 PM
No its not engaged. Well I bought some, but when I went to go pick them up,(from dealer) I found out they were for the front! So I have to sort that out.
Old Feb 10, 2006 | 07:26 PM
they arent required, but your pads will be a lot more noisy. make sure there is nothing between the rotors and the hubs. did you screw in the rear caliper pistons? you need a special tool(looks like a cube, and attaches to a socket wrench) available at any auto stores to compress the rear pistons so that you can put on the thicker pads.
Old Feb 10, 2006 | 07:42 PM
wec2002's Avatar
If your careful, you can use a pair of needle-nose to screw the piston back in. At least that's how I do it. Too cheap to but the tool and it has worked well for me in the past.
Old Feb 10, 2006 | 07:46 PM
fonseca's Avatar
The tool is only $8 or so at Advance Auto. It makes things a lot easier.
Old Feb 10, 2006 | 10:52 PM
Ive got it compessed as far as I can with needle-nose pliers and I can get the caliper on, but it just wont sit right.
Old Feb 11, 2006 | 02:06 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
are you sure that caliper will fit your car?
can you post a pic? (not forget to resize it wink1.gif )
Old Feb 11, 2006 | 10:30 AM
try putting the caliper bracket on first, snap the brake pads in there, and then the caliper over it.
Old Feb 11, 2006 | 12:21 PM
I know that D and I both had problems with the sliding pins. Do yours move easily and freely? These are the parts that the caliper bolts to. They have little rubber boots on them.
