Wheel Problem!
Old Mar 24, 2006 | 03:30 PM
IJSTBRNDU's Avatar
OK, i just noticed that my right rear wheel assy moves just by pushing on it. What's the problem? my hub bearing?
Old Mar 24, 2006 | 03:33 PM
KayJai's Avatar
Moves how?
you mean like wobbling back and forth?
Old Mar 24, 2006 | 03:54 PM
IJSTBRNDU's Avatar
the wheels moves toe in/out...so if ur behind the car it goes left to right...about .5 inch or so...im going under tonight to take a loook but i need all the help i can get since its a big saftey issue.
Old Mar 24, 2006 | 09:51 PM
Rd1tib's Avatar
sound like the wheel does nto sit flush to the hub
Old Mar 25, 2006 | 01:26 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
hmm, are you sure your wheel is tighten ok?
it maybe wheel bearing or bushings, check all bolts connections
Old Mar 25, 2006 | 07:51 AM
Stock or aftermarket?
Old Mar 25, 2006 | 10:11 AM
IJSTBRNDU's Avatar
yea the rims fit perfectly...aftermarket and had them for 3 yrs now...i'm checking everything out now..its all torqued down right sooo we'll see.
ok, i'm pretty positive its my rear suspension arm bushing
should i get just the one bushing or get the yaya kit and replace them all instead of waiting for the others to crap out?
Old Mar 25, 2006 | 11:31 AM
Dmitry's Avatar
Inspect all bushings and all suspension. Bad bushings can cause wheel alignment to change during drive.
Today I inspected my rear suspension and found 5 bad bushings, so on Monday I'll be changing them, probably all 12 bushings, don't whant to mess with bushings in near future, after alignment is done).
After you replace bushings it's recommended to do wheel alignment.
I'm interested too, how good are yaya bushings?
