Extremely Loud Crunching And Cracking
Vehicle: 1997 Hyundai Tiburon FX
I keep hearing painful "Crunching, grinding, and crackling..." sounds come from what seems to be the front passenger side wheel. Im guessing its the bearing but could it be more? I just got a new tranny put into the tib and the person who helped me with it said that, that one bearing was starting to give. that was 1700 miles ago. If its not just the bearing what else could it be? also how hard would it be for me to do the bearing alone? if i cant, how much should the bearing cost me and how much should the install cost? Im far from home(MIAMI, FL=home; Tucumcari, NM=small @$$ town im stuck in.) Any and all answers would be helpful thanx.
LOL, bearing issues are funny, they sound SOOOOOO bad, but cost 20 bux to fix.
Do this, go to the store, any autoparts store, buy 2 new bearings, one for later just in case. If you get a nice price, it'll be 17.99. Bad is 30 bux. But get two really, its just nice to have.
Take off your whole hub assembly, use a fork to remove the knuckle and all that. Then take the whole piece, minus rotors, to the metal shop. Tell them you'll give em 20 bux to pull the old bearing and press in a new one. They'll do this. If they wont, tell em to F-off and the next shop will.
Once you get the part back, put it back on, be careful not to puncture the rubber boots on the ball joints. Then once you have it back on, go get that b!tch aligned and you're good. The whole process costs me 77 bux. Thats the part, the work, the alignment, and knowing you just saved at least 200 bux from some dumb shop to do it!
When do you hear it? When turning? All the time? It also sounds like it may be a seized up caliper or CV joint (that is if it's not the bearing)
If you only hear it when accelerating into/out of a corner, then it's probably a CV joint.
If it was a seized caliper I think you'd know it...
If neither of those, then it's going to be the bearing, do exactly what blacktibs said. And I'd replace both sides while you're at it.
Quick painless test...
Jack up the front of the car. Enough for about 6 inches or so beneath the wheel. Take one hand at the bottom of the wheel, and one hand at the top, and try to rock it towards you. A good bearing will not move out at all. A bad bearing will wobble.
considering im on a time constraint and in the middle of no where. 31 for bearings 20 for shipment 35 for pressing and 75 for assembly removal. thats 161 + tax... imma cry. i dont think ill make it to SF cali if you include gas... i should have the tools to get the assembly off if someone would be nice enough to hook me up n explain/ show me how.
also you hear it whenever the wheel moves
Hope you get there. Should have called me.
I know you worked with Faith on this some, but seriously, doode, we could have helped ya out earlier.
I tolf Faithofadragon you could use my front hub(s) and just ship them back once you were at San Fran...
what happened? You get everything worked out?
175 miles on a sploded bearing is notta good.
