Wheel Shaking While Accelerating?
Hey all, I can feel and hear some vibration when accelerating. It sounds like its coming from the wheels, perhaps the driver side. It doesn't shake the stearing wheel, but I can hear and feel the slight shaking.
The last time I experienced a similar problem on my other vehicle (Eclipse) it ended up being bent rims. I will check the rims this Saturday, does anyone have any other suggestions of what it may be? thanks for looking.
BTW this is for my new Tibby - owned it for 4 days.
yes its prob a bent rim/wheel, i am having the same problem now.
i got a flat driving home from work in a blizzard a month ago and didnt feel like getting out to change it. now with a new tire on there it shakes like crazy at 40+ mph and i can also feel it in the brakes at higher speeds
QUOTE (TibFreak @ Dec 5 2008, 08:21 AM)
Knowing the Tib like I do, after having it for 7 years, I would go with wheel bearing.
I will start with the simplest least expensive things first, like a wheel balancing.
Is there a way to check for a bad wheel bearing?
Wheel bearings humm when they go bad as well. First at high speeds then as they get worse they hum at lower speeds. If you can move your tires, its either a ball joint or tie rod.
QUOTE (Rayne9707 @ Dec 4 2008, 08:00 PM)
Wheel bearing, Need Alignment, Balance Tires, Mabey a broken belt in a tire, These all have caused my car to vibrate
Congrats on the Tib.
Even low air pressure in the tire can cause it to shake/wobble/veer to the side. Check everything suggested above.
Does it do it at all speeds, or only 35+ / 50+ ? Does it change if you're pressing the brake/accelerator?
I had this happen to me, and it ended up being a broken wheel stud. It could be a number of different things associated with your wheels.
I would take the wheel off and put it back on. It might just not have tight lug nuts. Are they factory or aftermarket wheels?
