Any Good Ideas?
Old Jun 30, 2006 | 11:39 AM
lilo shark's Avatar
anyone have any good ideas on how to get some wheels that are stuck on your car off?
Old Jun 30, 2006 | 11:43 AM
screwdriver and a mallet right inbetween the rotor hat and the part of the wheel that is against it.
Old Jun 30, 2006 | 11:56 AM
Casper's Avatar
Okay, on a serious note, I would sit on the ground and kick the tire alternating feet (and sides of tire) and they usually come off. If its resistant, you can spin the tire a 1/4 turn and keep going etc.
Old Jun 30, 2006 | 01:12 PM
hamhead's Avatar
You can't take them off with a breaker bar?
Old Jun 30, 2006 | 01:20 PM
KayJai's Avatar
I think what he means is the nuts are off, but the wheel is stuck to the rotor.
If it's on a hoist, I usually put one nut back on by hand half way, and pretend I'm the karate kid and do a round house to knock it loose, usually works, sometimes takes more than one try lmao.gif
If it's on the ground and you are using say a floor jack, I'd probably use jackstands so that your rotor doesn't fall on the ground if it slips and use the same one bolt on and kicking method
Old Jun 30, 2006 | 02:46 PM
lilo shark's Avatar
i was kicking it like crazy and gave up. i'm going to try again tommorow cause i got to hit the tracks today. i aleast got the front off.
Old Jun 30, 2006 | 06:33 PM
landshark16's Avatar
Try kicking it from the back of the tire if you already haven't.
Old Jun 30, 2006 | 06:58 PM
Zman's Avatar
You can also try:
a) Loosen all nuts and then put one nut and tight it very hard (not too hard so you can't take it back out) and THEN kick the wheel; repeat for at least two different nut positions.
and if that fails:
b) apply some HD WD40 on the wheel-rotor union on your front yard or a quiet place to move the car a little, put the 4 nuts back there and tight them just by hand, then drive the car front and backwards for some meters repeatedly, it sometimes helps loosen the wheels.
Old Jun 30, 2006 | 08:19 PM
Or remove all the nuts on the affected wheel, then drive around taking corners really fast... That should make it come loose fing02.gif j/k
Old Jul 1, 2006 | 07:38 AM
lilo shark's Avatar
Ozfx i'm not an idiot. i want to get it off not fvck my car up.
