Tread Measurement... Penny vs. Actual Gauge
Hi,
I normally just use a penny to measure my tread (thanks to my dad for telling me that trick) but when I used a penny to measure two michelins they were covering a small portion of lincolns head for around (2-3/32) but the tread gauge at the mechanics read 6/32.
The tire guy said michelins can't be measured with the penny cause of the grooves..
Anybody heard of this?
Vehicle: 2001 Hyundai Tiburon 2.0 G4GF-EG
use 1€ coins
half of the outermost ring (3mm) approximately corresponds with minimum tread requirement over here (1.6 mm). Minimum tread recommended by the manufacturer is also indicated on the tire itself by wear bars.
You need to check inside and ouside of the tire for uneven wear. Use a new coin.
If those were normal michelin tires for street use (slicks are illegal over here) your tire guy was wrong.
half of the outermost ring (3mm) approximately corresponds with minimum tread requirement over here (1.6 mm). Minimum tread recommended by the manufacturer is also indicated on the tire itself by wear bars.You need to check inside and ouside of the tire for uneven wear. Use a new coin.
